EduardoSantos 40 Posted August 29, 2018 Posted August 29, 2018 This is kind of weird... This MP3 track is being detected with wrong time signature by Emby. When Emby plays it will stop streaming it just 3 seconds after begining. If I remove the cover image using MP3Tag, Emby scans ok and plays ok. If I insert the image back using MP3Tag, Emby scans it wrongfully again. Every other player I tested (e.g.: VLC and Groove) plays the track ok with or without the embedded image. Shall I provide the track? Server logs?
EduardoSantos 40 Posted August 29, 2018 Author Posted August 29, 2018 Just tested the MP3 track on other two servers. Emby can't detect the time signature on none of them. Also I did check the file by using "Checkmate MP3 Checker" and it says the file is ok.
Luke 42213 Posted August 29, 2018 Posted August 29, 2018 What does "can't detect the time signature" mean?
EduardoSantos 40 Posted September 4, 2018 Author Posted September 4, 2018 (edited) Track gets wrong lenght on Emby's database as you can see on the attached image. Also, when trying to play it:- The sound is weird - Emby will stop casting at 9 seconds. The first track has no embedded image and the second one has the cover image embedded.Almost all my tracks have embedded cover images but this occurs only on this track. Edited September 4, 2018 by EduardoSantos
Luke 42213 Posted September 5, 2018 Posted September 5, 2018 Can you zip it up and attach it here? thanks.
EduardoSantos 40 Posted September 20, 2018 Author Posted September 20, 2018 As requested, Sonata (Trio) in B flat major, KV266271f 1 Adagio.zip
Luke 42213 Posted September 20, 2018 Posted September 20, 2018 Ok yes i can reproduce. That's the runtime coming from ffprobe. I verified it using the ffprobe command line so there might not be much we can do about this one file.
EduardoSantos 40 Posted September 21, 2018 Author Posted September 21, 2018 (edited) Thanks anyway! Should I direct my problem to the FFmpeg forum? Or would you guess this is actually a MP3Tag error? Edited September 21, 2018 by EduardoSantos
Luke 42213 Posted September 21, 2018 Posted September 21, 2018 Well i guess the question is where is ffprobe pulling the duration. If it's embedded metadata, then maybe mp3tag.
