HTTPS page not loading though load balancer
I'm trying to get all of my websites to run though a load balancer so I can have all of my HTTPS traffic go out over port 443. I'm using KEMP Free load balancer and i can get Emby to work over port 80 with HTTP, but the site will not load over HTTPs. Has anyone had any luck doing anything similar? When I go to https://emby.example.com from out side my house i get a black page. The login info never shows. I've attached a log. most of my testing was between 2018-08-28 07:00 and  2018-08-28 07:23
mastrmind11
HTTPS uses 443 by default.  What are you trying to solve for?
Did you forget to attach the log?
RobWayBro
Is your Emby server using 443 for https?  By default it uses 8920.
I forgot to hit "Attach This File"
log.txt
I only have 1 public IP address. I'm trying to pass all of my HTTPS traffic over port 443 (i have 3 other devices also using this port) the load balancer is looking at the host header and passing the requests to the real sever. I'm using the default ports for emby and the the load balancer is exposed to the internet on port 443.
Edited by andcbii
Here is a second log file. I've noticed if i just keep hitting refresh the page eventually loads.
log2.txt
I monkeyed with the LB for a while and now everything is working.
Thanks for the feedback !
