roberthleeii 62 Posted August 28, 2018 Posted August 28, 2018 I have made the transition to using emby as my primary and only TV ecosystem in my house. I have a rokus at each of my TVs and the thumbnail plugin is a great addition. The only problem is that some of my generated thumbnails don't complete and I only get thumbnails for part of the recording. I could survive with out the thumbnails for the rest of the recording but it does not let you fast forward past the end of the thumbnails. When you try to ff or rw it always goes back to the end of the thumbnails even if you were an hours past that point. If I go delete the .bif file and make the plugin run again it will generate a complete file. Is there any thing I can do to fix this issue? Sent from my SM-N960U using Tapatalk
ebr 16335 Posted August 28, 2018 Posted August 28, 2018 Hi. Can you capture a server log when the plug-in doesn't complete a video?
Erik 124 Posted August 28, 2018 Posted August 28, 2018 I had a similar issue in the past and I believe it was due to the thumbnail plugin running while a liveTV show was being recorded. I'm my case I just have the plugin scheduled to run during times that I don't record shows. Also, don't manually run the plugin while a recording is in progress. See if that fixes it for you.
roberthleeii 62 Posted August 28, 2018 Author Posted August 28, 2018 Hi. Can you capture a server log when the plug-in doesn't complete a video?I am going to try. I usually don't find out until I watch it and don't know when it recorded. I am going to pay more attention. Sent from my SM-N960U using Tapatalk
roberthleeii 62 Posted August 28, 2018 Author Posted August 28, 2018 I had a similar issue in the past and I believe it was due to the thumbnail plugin running while a liveTV show was being recorded. I'm my case I just have the plugin scheduled to run during times that I don't record shows. Also, don't manually run the plugin while a recording is in progress. See if that fixes it for you. Ok. I looked at the timing of the recordings and when the scheduled taks is running and that may be my issue. I have deleted the scheduled task and changed it to create the thumbnails when it discovers new media. Sent from my SM-N960U using Tapatalk
Luke 42243 Posted August 28, 2018 Posted August 28, 2018 I'm updating the plugin for the next server release to guard against this. Thanks. 2
roberthleeii 62 Posted September 2, 2018 Author Posted September 2, 2018 I'm updating the plugin for the next server release to guard against this. Thanks. That's great!! Now that I have made Emby my primary and only TV watching source in our house this is one of the few problems I am having. I wish I would have switched over sooner and saved all that box renting money I was sending to comcast.
sfatula 208 Posted September 28, 2018 Posted September 28, 2018 I'm updating the plugin for the next server release to guard against this. Thanks. Did 3.5.3.0 not count as the next version? Still happens for me.
Happy2Play 9811 Posted September 28, 2018 Posted September 28, 2018 (edited) Did 3.5.3.0 not count as the next version? Still happens for me. No it was a hot fix for issues that arose with Chrome 69 update. 3.6.x.x will be the next update Edited September 28, 2018 by Happy2Play 1
roberthleeii 62 Posted September 28, 2018 Author Posted September 28, 2018 No it was a hot fix for issues that arose with Chrome 69 update. 3.6.x.x will be the next updateI was wondering why it was still happening. Thanks for the update. Is there any estimates timeframe for 3.6 release to public? Sent from my SM-N960U using Tapatalk
