seanfletcher255 4 Posted January 1, 2024 Posted January 1, 2024 On 8/28/2018 at 12:26 AM, Luke said: Hi, while I think this is a neat idea, I'm not sure when we'll ever be able to prioritize it ahead of other features. First, before you could even think about muting the audio, you need a database of voice data for every single video in your library. Then a player could read that data and mute accordingly. But does anything even exist to create that kind of data? I'm really not sure. here is some php code that tries to read in an srt file then parse it for the word and create a mute codes for a n EDL file <?php include(__DIR__ . "/../functions.php"); //error_reporting(2047); $srt = $argv[2]; $words = explode(",",$argv[1]); $parts = fletch_parse_srt_file($srt); $SaveTo = (empty($argv[2])) ? 'php://stdout' : ffat_get_filename($argv[2]) . '.edl'; foreach($parts as $sub) { foreach($words as $word) { /*If $word is not in the subtitle then continue on*/ if(strpos($sub['Text'],$word) !== false ) { foreach($sub['Words'] as $wordArray) { if(preg_match('#'.preg_quote($word,'#i').'#',$wordArray['Word']) > 0) { $startTime = fletch_convert_time($wordArray['Pos_Start']); // this function just converts the timestamp to seconds $stopTime = fletch_convert_time($wordArray['Pos_End']);// this function just converts the timestamp to seconds fletch_flix_write_edl($SaveTo,$startTime,$stopTime,"1"); // does the actual writing of the edl file } } } } } ?> <?php function fletch_parse_srt_file($File) { $lines = preg_split("#\r\n\s#Uis",file_get_contents($File)); $i = 1; foreach($lines as $line) { if (!empty(trim($line))) { $count = count(explode("\n",$line)); if($count >= 4) { @list($Crap, $ID, $TimeCode, $TextLine1, $TextLine2) = explode("\n", $line); } else { @list($ID, $TimeCode, $TextLine1) = explode("\n", $line); } @list($StartRaw, $EndRaw) = explode("-", str_replace(" --> ", "-", $TimeCode)); @list($Start, $Micro) = explode(",", $StartRaw); @list($End, $Micro) = explode(",", $EndRaw); $array[$i]['ID'] = trim($ID); $array[$i]['TimeCode'] = trim($TimeCode); $array[$i]['TimeStart'] = $Start; $array[$i]['TimeEnd'] = $End; $array[$i]['Text1'] = trim($TextLine1); if($count >= 4) { $array[$i]['Text2'] = trim($TextLine2); } $array[$i]['Text'] = strip_tags(trim($TextLine1) . ' ' . trim($TextLine2 ?? '')); $array[$i]['SubTitleSize'] = $count; $tmp = explode(" ", $array[$i]['Text']); //die(print_r($tmp,true)); $j=0; foreach ($tmp as $Word) { $Word = str_replace(array(',',"'",'"','?','-','!','.'), "", $Word); if (!empty($Word)) { $array[$i]['Words'][$j]['Length'] = strlen($Word); $array[$i]['Words'][$j]['Pos_Start'] = fletch_format_time(fletch_convert_time($Start)+strpos($array[$i]['Text'], $Word), 'timecode'); $array[$i]['Words'][$j]['Pos_End'] = fletch_format_time(fletch_convert_time($Start)+strpos($array[$i]['Text'], $Word)+fletch_convert_time($array[$i]['Words'][$j]['Length']), 'timecode'); $array[$i]['Words'][$j]['Word'] = $Word; } $j++; } $i++; } } return $array; } ?> kodi supports edls doing this same thing but emby has more features for me so thats why i am with emby not kodi but anyway
roaku 842 Posted January 2, 2024 Posted January 2, 2024 11 hours ago, tmurphy2792 said: @BillOatmanThanks for the feedback. So I continued to play with them last night and came to the unfortunate realization that because I use roku devices for the vast majority of my watching, neither of these plugins will work for me. I can be watching from a web browser and have it skip and mute beautifully, but the roku devices play the stream completely uninterrupted without skips or mutes. To my understanding from finding some of your other posts, this is a limitation of the client app, correct? MKVToolNix: Thanks for that suggestion, want to say I've played with this one in the past. I'll test to see if it works with the .TS files I'm receiving from my over the air antenna. I don't use the profanity plugin, but I do use comskipper and have no issues with it working on Roku. 1
ebr 16337 Posted January 2, 2024 Posted January 2, 2024 11 hours ago, roaku said: I don't use the profanity plugin, but I do use comskipper and have no issues with it working on Roku. Right it should work fine on Roku as long as it is the local LAN. Roku does not allow remote control off network though. 1 1
BillOatman 597 Posted January 2, 2024 Posted January 2, 2024 (edited) On 1/1/2024 at 10:26 AM, tmurphy2792 said: @BillOatmanThanks for the feedback. So I continued to play with them last night and came to the unfortunate realization that because I use roku devices for the vast majority of my watching, neither of these plugins will work for me. I can be watching from a web browser and have it skip and mute beautifully, but the roku devices play the stream completely uninterrupted without skips or mutes. To my understanding from finding some of your other posts, this is a limitation of the client app, correct? MKVToolNix: Thanks for that suggestion, want to say I've played with this one in the past. I'll test to see if it works with the .TS files I'm receiving from my over the air antenna. Based on the posts above, your Roku should work as long as it is on the same network as the server. PottyMouth and Comskipper both use the same commands to skip forward, so the Roku should be fine for both plugins. After verifying your Roku Emby client is at the latest version, if you cannot get it to work: Turn debug logging on in the server. Play a video past where it should have skipped a undesired word. Send me the log file, about what time you played the video, and the EDL file, and the srt files for the video generated by PMFileGenerator. Turn off debug logging. Edited January 2, 2024 by BillOatman
rbjtech 5344 Posted January 2, 2024 Posted January 2, 2024 59 minutes ago, BillOatman said: Based on the posts above, your Roku should work as long as it is on the same network as the server. PottyMouth and Comskipper both use the same commands to skip forward, so the Roku should be fine for both plugins. After verifying your Roku Emby client is at the latest version, if you cannot get it to work: Turn debug logging on in the server. Play a video past where it should have skipped a undesired word. Send me the log file, about what time you played the video, and the EDL file, and the srt files for the video generated by PMFileGenerator. Turn off debug logging. Do you use the same API call as Introskip did @BillOatman? - As i seem to recall you developing this the same time as @chef+ @Cheesegeezer(and I) did for the original Introskip plugin ? If yes, does that also mean Introskip does not work remotely on the Roku ? If no, how is the Core achieving what the Plugin did not - re skip to position x remotely on the Roku ?
ebr 16337 Posted January 2, 2024 Posted January 2, 2024 3 hours ago, rbjtech said: does that also mean Introskip does not work remotely on the Roku ? If it is trying to send remote commands, then yes. Roku does not allow any remote control that is not originating on the local network. Security thing for them. 3 hours ago, rbjtech said: how is the Core achieving what the Plugin did not Each app has the logic built in so no remote control is necessary. 1
BillOatman 597 Posted January 3, 2024 Posted January 3, 2024 6 hours ago, ebr said: Each app has the logic built in so no remote control is necessary. @rbjtechYes the original plugin did it the same way as comskipper and pottymouth. But like ebr says, when it got moved into core they were not limited to the same things plugins are which explains why introskip works so smooth now. 1
speechles 2062 Posted January 3, 2024 Posted January 3, 2024 (edited) The Roku does allow the video node to mute and unmute the audio during video playback. I am sure most devices allow the same. Perhaps in the future the pottymouth could be made to activate the mute/unmute of each app at the appropriate time in the same vein as each app handles intro skipping. That is possible and much better than just skipping past and causing seek delays. Would just need custom markers for the potty mouth entries so the app can tell them from chapters and intro/outro markers. Doing it this way would work on any Roku using either remote or local connections. Edited January 3, 2024 by speechles
rbjtech 5344 Posted January 3, 2024 Posted January 3, 2024 (edited) 6 hours ago, speechles said: The Roku does allow the video node to mute and unmute the audio during video playback. I am sure most devices allow the same. Perhaps in the future the pottymouth could be made to activate the mute/unmute of each app at the appropriate time in the same vein as each app handles intro skipping. That is possible and much better than just skipping past and causing seek delays. Would just need custom markers for the potty mouth entries so the app can tell them from chapters and intro/outro markers. Doing it this way would work on any Roku using either remote or local connections. Agreed and this is something originally discussed with the core team when the Core introskip decided to use 'hidden' chapter markers. There is nothing to stop there being different types of markers - not only for Intro Start, Intro Stop, Credit Start, Credit Stop - but also some more advanced markers such as Mute Start, Mute Stop and even Recap Start, Recap Stop etc for those that want to skip recaps - if manually edited (Previously on ..) etc. Unfortunately, there is still a lot missing from the Core Introskip installation vs the Plugin - such as editing, yes there are some Plugins that fill the gaps - but as the core framework 'could' easily add this more advanced functionality - it's a shame it has never been implemented. Personally, I still use the Plugin with the hidden markers being written by the Plugin - thus using the Core 'skip' functionality, but the more advanced detection/editing capabilities of the Plugin. 6 hours ago, BillOatman said: @rbjtechYes the original plugin did it the same way as comskipper and pottymouth. But like ebr says, when it got moved into core they were not limited to the same things plugins are which explains why introskip works so smooth now. Sure - this makes sense - the Introskip Plugin writes the hidden markers as well (if that option is ticked) and thus I use the Core client to do the skipping. Next episode skip has not yet been implemented however - so if you want it to skip to next episode on Credit Start, then you still need to use the Plugin. I guess if the muting markers were ever implemented (in the core) then your Plugins could simply write them and let the client do all the work - and this remote Roku (or any client) issue would be resolved ? Edited January 3, 2024 by rbjtech 1
tmurphy2792 29 Posted January 20, 2024 Posted January 20, 2024 On 1/2/2024 at 10:57 AM, BillOatman said: Based on the posts above, your Roku should work as long as it is on the same network as the server. PottyMouth and Comskipper both use the same commands to skip forward, so the Roku should be fine for both plugins. After verifying your Roku Emby client is at the latest version, if you cannot get it to work: Turn debug logging on in the server. Play a video past where it should have skipped a undesired word. Send me the log file, about what time you played the video, and the EDL file, and the srt files for the video generated by PMFileGenerator. Turn off debug logging. Sorry for the delayed response Bill. Got back into the work swing after the new year and apparently missed these notifications. So I had been initially testing by inserting arbitrary timestamps into the edl file generated by comskip. I've since taken the time to set up a batch file to trigger comskipper, CCExtractor, and PMFileGenerator. In attempting to do that though, I'm finding PMFileGenerator doesn't seem to want to work on my host machine (win10 mini PC) it runs for a spell till I run out of RAM then it stops with a message about running out of memory in the command window. Not sure what's up with that, but I hadn't put much effort into trying it on other machines since the plugin doesn't seem to want to work for me. That being said, here are the files you requested. For testing I was using a live tv recording of Sons of Katie Elder and the .edl file was initially created by comskip. I then added the single mute line for testing PottyMouth extension. (I do not currently have comskipper installed as my initial idea was PottyMouth would be fill both needs). To make it as easy as possible to read the debug file, I started playing the file as close to exactly 2024-01-20 16:58 as humanly possible. Thanks again for the help comskip manual.bat embyserver.txt The Sons of Katie Elder (1965).edl
BillOatman 597 Posted January 21, 2024 Posted January 21, 2024 5 hours ago, tmurphy2792 said: Sorry for the delayed response Bill. Got back into the work swing after the new year and apparently missed these notifications. So I had been initially testing by inserting arbitrary timestamps into the edl file generated by comskip. I've since taken the time to set up a batch file to trigger comskipper, CCExtractor, and PMFileGenerator. In attempting to do that though, I'm finding PMFileGenerator doesn't seem to want to work on my host machine (win10 mini PC) it runs for a spell till I run out of RAM then it stops with a message about running out of memory in the command window. Not sure what's up with that, but I hadn't put much effort into trying it on other machines since the plugin doesn't seem to want to work for me. That being said, here are the files you requested. For testing I was using a live tv recording of Sons of Katie Elder and the .edl file was initially created by comskip. I then added the single mute line for testing PottyMouth extension. (I do not currently have comskipper installed as my initial idea was PottyMouth would be fill both needs). To make it as easy as possible to read the debug file, I started playing the file as close to exactly 2024-01-20 16:58 as humanly possible. Thanks again for the help comskip manual.bat 575 B · 0 downloads embyserver.txt 8.72 MB · 0 downloads The Sons of Katie Elder (1965).edl 333 B · 0 downloads This was in the log file. Quote Info Potty Mouth: Playback Session 34bdb3d7bfe7e38245e288e28777af9b Path H:\LIVE TV\MOVIES\The Sons of Katie Elder (1965)\The Sons of Katie Elder (1965).ts. Mute is not supported. Not possible to mute out the desired audio. So your device is not able to mute the audio via the plugin command. Curious about the out of memory error. Please send me a subtitle file that gives you the out of memory mehavior.
ebr 16337 Posted January 21, 2024 Posted January 21, 2024 Hi. Please troubleshoot plugin problems in a separate thread. Thanks.
fgty45 1 Posted August 13, 2025 Posted August 13, 2025 This youtube vanced. Auto Removal/Bleeping of Swear Words 1
hjason7812 35 Posted August 14, 2025 Posted August 14, 2025 On 8/28/2018 at 1:18 AM, wowsers said: @Luke: what's the best way to implement this feature (assuming I hire a developer)? Allow Emby users to filter out (mute) common profanity words, e.g f--k, s--t, etc. The workflow looks like this: User goes to the server settings page, goes to a config page (a plugin?), chooses the words they don't want to hear, and hits Save. Emby compares the word list to the subtitle file of each video. When there are matches, Emby mutes the audio at the appropriate time during playback (between the start and stop time of each line in the sub file where there is a match). Thanks! why in the world would you want to do this? it would ruin the content of the movie or show you are watching because the beeping drowns out the rest of what they're saying most of the time. if you don't like cussing then don't watch anything but cartoons and religious content sorry but that is the truth 1
brothom 211 Posted August 14, 2025 Posted August 14, 2025 33 minutes ago, hjason7812 said: why in the world would you want to do this? it would ruin the content of the movie or show you are watching because the beeping drowns out the rest of what they're saying most of the time. if you don't like cussing then don't watch anything but cartoons and religious content sorry but that is the truth I'm pretty sure that's like, your opinion. While I agree it takes away from the experience, people are free to do whatever they want. I.e.: I like to watch South Park. Uncensored. My kids like South Park because it's a cartoon, let's censor it a little bit Regardless, a consistent solution to this issue would be to have an additional audio track that contains the original audio but is censored. After Googling a bit I found a bunch of tools that claim to be able to scan audio files and censor them like Cursecut, Cleanvoice AI or maybe Bleep That Sh*t!. Feed these a separate (copy) of the original audio and let them do their work. Call it "original-censored.mp4" or whatever and feed it as a separate audio track. 1 1
BillOatman 597 Posted August 15, 2025 Posted August 15, 2025 (edited) 19 hours ago, brothom said: I'm pretty sure that's like, your opinion. While I agree it takes away from the experience, people are free to do whatever they want. I.e.: I like to watch South Park. Uncensored. My kids like South Park because it's a cartoon, let's censor it a little bit Regardless, a consistent solution to this issue would be to have an additional audio track that contains the original audio but is censored. After Googling a bit I found a bunch of tools that claim to be able to scan audio files and censor them like Cursecut, Cleanvoice AI or maybe Bleep That Sh*t!. Feed these a separate (copy) of the original audio and let them do their work. Call it "original-censored.mp4" or whatever and feed it as a separate audio track. Have a look at this, it might do what you need. Potty Mouth Plugin Edited August 15, 2025 by BillOatman
brothom 211 Posted August 15, 2025 Posted August 15, 2025 5 hours ago, BillOatman said: Have a look at this, it might do what you need. Potty Mouth Plugin I understand you'd see the relation between this feature and your plugin but the primary disadvantage of plugins and implementations like that, is that theýre focussed on censoring based off of a text (srt) file which is not only counterintuitive but can also be wrong. Some sentences are pronounced much quicker than their screentime, making plugins like these simply "miss' the profanity. Personally I would prefer this is done based off of the actual audio track for consistency reasons and not just "guess" where profanity is within the timeline. Besides, there are multiple subtitle files, multple versions of the same video which not always overlap 100% so it's basically using a technology of which you know that it's setup to fail eventually.
BillOatman 597 Posted August 15, 2025 Posted August 15, 2025 8 hours ago, brothom said: I understand you'd see the relation between this feature and your plugin but the primary disadvantage of plugins and implementations like that, is that theýre focussed on censoring based off of a text (srt) file which is not only counterintuitive but can also be wrong. Some sentences are pronounced much quicker than their screentime, making plugins like these simply "miss' the profanity. Personally I would prefer this is done based off of the actual audio track for consistency reasons and not just "guess" where profanity is within the timeline. Besides, there are multiple subtitle files, multple versions of the same video which not always overlap 100% so it's basically using a technology of which you know that it's setup to fail eventually. I was curious when I saw your earlier post about using audio directly so I took a look and near as I can tell, they all seem to use an AI model such as Whisper to go audio to text, then remove the offending words. I'm not sure how else you would do it honestly. "Official" (not AI generated) subtitles would tend to be more accurate in that case. But to each his/her own. Always good to have options.
crusher11 1143 Posted August 16, 2025 Posted August 16, 2025 23 hours ago, brothom said: I understand you'd see the relation between this feature and your plugin but the primary disadvantage of plugins and implementations like that, is that theýre focussed on censoring based off of a text (srt) file which is not only counterintuitive but can also be wrong. Some sentences are pronounced much quicker than their screentime, making plugins like these simply "miss' the profanity. Personally I would prefer this is done based off of the actual audio track for consistency reasons and not just "guess" where profanity is within the timeline. Besides, there are multiple subtitle files, multple versions of the same video which not always overlap 100% so it's basically using a technology of which you know that it's setup to fail eventually. So you want a solution that is automated, requires zero effort, and is perfect?
