pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 (edited) ok so now what hahaha?? could it be the new install method or something? I used to apt-get my emby-server now I do the manual install. this is running on debian 8.1 Edited August 29, 2018 by pr3dict
Luke 42246 Posted August 29, 2018 Posted August 29, 2018 It still sounds to me like you have something in front of emby server that is tampering with the requests.
pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 I dont understand how you came to that conclusion? The only devices affected are Android devices, aka phones, fire TV's etc... Windows direct plays it fine. Chrome Direct plays it fine... Also I added the server directly by IP address without SSL on the same subnet as the server and still same issue. As I said earlier, VLC comes up with an error that says "cannot load http:\\blahblahblahlbhal.com/stream/dfblahblahsdfkjshdfjekjhsdjfhsje" Is it possible that android devices aren't liking the long address that it is popping out?
pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 (edited) The following is my logs from my proxy when I click on a video to play it. Aug 29 02:20:01 haproxy[41168]: xxx.xxx.xxx.xxx:xxxx [29/Aug/2018:02:20:01.626] Emby_Frontend_SSL-merged~ embySSLBackend-10_ipvANY/Emby-10-SSL 0/0/0/2/2 204 611 - - ---- 4/4/0/1/0 0/0 "POST /Sessions/Playing/Progress HTTP/1.1" Aug 29 02:20:01 haproxy[41168]: xxx.xxx.xxx.xxx:xxxx [29/Aug/2018:02:19:50.172] Emby_Frontend_SSL-merged~ Emby_Frontend_SSL-merged/<NOSRV> -1/-1/-1/-1/11455 400 187 - - CR-- 4/4/0/0/0 0/0 "<BADREQ>" Aug 29 02:20:01 haproxy[41168]: xxx.xxx.xxx.xxx:xxxx [29/Aug/2018:02:19:50.162] Emby_Frontend_SSL-merged~ Emby_Frontend_SSL-merged/<NOSRV> -1/-1/-1/-1/11463 400 187 - - CR-- 5/5/0/0/0 0/0 "<BADREQ>" Aug 29 02:19:52 haproxy[41168]: xxx.xxx.xxx.xxx:xxxx [29/Aug/2018:02:19:52.882] Emby_Frontend_SSL-merged~ Emby_Frontend_SSL-merged/<NOSRV> -1/-1/-1/-1/0 503 212 - - SC-- 6/6/0/0/0 0/0 "GET /Videos/36462da9e8e2ab39c9f6fcbdbf546690/stream.mkv%3FStatic=true&mediaSourceId=36462da9e8e2ab39c9f6fcbdbf546690&deviceId=8c8e26c26dd32e90&api_key=ab589a3e634746ddb8992f3b88ea87e8&Tag=402b393f91c2b354bfcccff234ff6e50 HTTP/1.1" Aug 29 02:19:51 haproxy[41168]: xxx.xxx.xxx.xxx:xxxx [29/Aug/2018:02:19:51.486] Emby_Frontend_SSL-merged~ embySSLBackend-10_ipvANY/Emby-10-SSL 0/0/0/1/1 204 611 - - ---- 6/6/0/1/0 0/0 "POST /Sessions/Playing HTTP/1.1" Ok so good news is I've figured out the weird error that it couldnt find the location. When clicking the video link it only sends what is after the FQDN and my proxy was losing it's shit because it was like ok what server do I send that string to? I gave it a default of the emby server so thats good but still not sure thats exactly what should be configured that way.... ANYWAY Still having an issue where it is trying to load up the entire video at once, thats making for some really long load times. I saw 1 other thread about this but didnt really see a good solution on how to fix it. Edited August 29, 2018 by pr3dict
Luke 42246 Posted August 29, 2018 Posted August 29, 2018 Are you using an old version of the Android app?
pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 Are you running an old version of the android mobile app? I'm on 3.0.1.0. Also it happens on a fire TV android app also. Only transcoding will play. Are you using an old version of the Android app? Lol sometimes I think you're screwing with me...
pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 I dont mean to be a **** but this is why I don't post logs because it seems they arent read haha... It says what device and version of android all over it. HTC U12+ Android 8.0.0 HTTP POST http://192.168.10.89:8096/emby/Sync/Data. UserAgent: Mozilla/5.0 (Linux; Android 8.0.0; HTC U12+ Build/OPR1.170623.032; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/68.0.3440.91 Safari/537.36 What device and version of android? What version of android? Really???
Luke 42246 Posted August 29, 2018 Posted August 29, 2018 Sorry the reason I keep asking if you're on an old version of the app, or old version of android, is because you keep mentioning vlc but our android apps don't use that anymore.
pr3dict 33 Posted August 29, 2018 Author Posted August 29, 2018 That's weird. The reason Im using vlc is because it gives me an error message when it doesn't work... In app player just silently doesn't work.
Luke 42246 Posted August 30, 2018 Posted August 30, 2018 Ok so that's an external player? That would have been good information to know earlier. Anyway, can you try using the internal player and then we'll look at that? thanks.
pr3dict 33 Posted August 30, 2018 Author Posted August 30, 2018 Luke, When I use the in-app player it would just spin and spin and spin and spin and spin and spin. That's weird. The reason Im using vlc is because it gives me an error message when it doesn't work... In app player just silently doesn't work.
Luke 42246 Posted August 30, 2018 Posted August 30, 2018 Can we look at the server and ffmpeg log from that? thanks.
pr3dict 33 Posted August 30, 2018 Author Posted August 30, 2018 It didnt generate an ffmpeg log but here is hte server log. emby server log 180830.txt
Luke 42246 Posted September 1, 2018 Posted September 1, 2018 Please try this version and then capture a log file from the app: https://www.dropbox.com/s/ppqiqlpdt3s099f/MediaBrowser.Mobile-googlearmv7debug-release.apk?dl=0 thanks.
pr3dict 33 Posted September 3, 2018 Author Posted September 3, 2018 Lol I have the "let this app install apps from unkown sources" on chrome and I downloaded the apk but my phone says it cannot open the file. any ideas?
Luke 42246 Posted September 3, 2018 Posted September 3, 2018 https://www.greenbot.com/article/2452614/how-to-sideload-an-app-onto-your-android-phone-or-tablet.html
