Luke 42237 Posted December 28, 2019 Posted December 28, 2019 I would follow the testing area of the community to see what's new in our beta releases. Thanks. 2
Jturquette 0 Posted September 23, 2020 Posted September 23, 2020 Any word on this? I see the suggestions for joining the files, but this also affects using downloaded subtitles. combining subtitle files is easy, but making sure the frame marker is correct will be a pain.
Xhatry 0 Posted March 10, 2021 Posted March 10, 2021 I'm also interested in this feature! It would be awesome to list my episode parts in one episode avoiding the joining parts in one file only. Thank you!
access 11 Posted March 18, 2021 Posted March 18, 2021 Yes, this would be very useful. A lot of animated series have two "Acts" as they are really two 10 minute shows combined for the television format, but really belong separately and are downloaded separately. Combining them wouldn't be the best course of action.
GrumpyTrucker 3 Posted April 7, 2021 Posted April 7, 2021 Good grief. I've been looking for an answer to this, being new to Emby and having a few episodes that are split into two. Seeing "we'll get to it" replies going back 5+ years in various threads isn't encouraging. So many shows are split into multiple parts for season/series finales and Pilots for broadcast then merged for commercial release. It really shouldn't be on us to be joining files after all this time. Emby is so far ahead of the competition in almost every other aspect, but this one that Plex has had for years still isn't there.
Luke 42237 Posted April 8, 2021 Posted April 8, 2021 Hi, we will get to it, but we would always suggest joining the files for the best possible experience.
SwanStream 64 Posted September 11, 2022 Posted September 11, 2022 On 4/8/2021 at 9:16 AM, Luke said: Hi, we will get to it, but we would always suggest joining the files for the best possible experience. I'm also interested in this "feature". I would join if possible, but some items, like sports, the pre/post are part of the episode in thetvdb, so can't be separated in episode #'ing, but are in different formats, i.e pre/post maybe are 1080p/60 while the 'event' is 4k/50 so can't be joined. Remux is possible, but not ideal, real time consuming, and a waste of disk space as one would likely upmix the 1080 to 4k rather than the other way around... or why bother with the 4k source, ya? 1
pdavis 1 Posted March 16, 2023 Posted March 16, 2023 I have to plus one this as well. I would love to see a Road Map with all suggested features that have been accepted. I assume the team has them written down somewhere. Maybe a periodic pole of the community to rank what is worked on next? Launchbox does such a pole periodically and it is awesome, really makes the community feel like there requests are getting addressed.
KellyEmby 13 Posted November 21, 2023 Posted November 21, 2023 How to name episode files with multiple parts? For me to fix the problem where TheTVDB has one episode that was later broken into multiple episodes: 1) I copy the episodes into their folder (for me it is usually series, I don't know about movies yet) 2) Then I click the name title (i.e., “S1:E1 – The Murder of Sherlock Holmes”), that brings up additional information about that episode 3) Then under “Media Info” I click “Split Versions Apart”, that separates all the versions, click OK 4) Now “Edit Metadata” for the separated versions to the order you wish Maybe the “Split Versions Apart” is a recent fix, only found this feature a few months ago where I used it a few times for a different problem where I had multiple versions of the same episode. I will remember this feature!! Thank you Emby!!
Luke 42237 Posted November 23, 2023 Posted November 23, 2023 On 11/21/2023 at 3:22 PM, KellyEmby said: How to name episode files with multiple parts? For me to fix the problem where TheTVDB has one episode that was later broken into multiple episodes: 1) I copy the episodes into their folder (for me it is usually series, I don't know about movies yet) 2) Then I click the name title (i.e., “S1:E1 – The Murder of Sherlock Holmes”), that brings up additional information about that episode 3) Then under “Media Info” I click “Split Versions Apart”, that separates all the versions, click OK 4) Now “Edit Metadata” for the separated versions to the order you wish Maybe the “Split Versions Apart” is a recent fix, only found this feature a few months ago where I used it a few times for a different problem where I had multiple versions of the same episode. I will remember this feature!! Thank you Emby!!
