4K Optical Drive
I just remembered my other question. It's about 4k. I have only seen 1 drive that's internal for a PC and it was about 160.00. i also read that its compatible with the newer intel processors and only certain mb's. Is this thing even worth buying right now?
Guest asrequested
What is it that you want to know, exactly? I'm not grasping the intent.
  • 2 weeks later...
legallink
I would hop on the makemkv forums. They have a lot of opinions on 4K drives
