saj 14 Posted August 24, 2018 Posted August 24, 2018 Hi, The most recent 4 or 5 updates to the Android app have broken emby on my Samsung Galaxy Note 3 running Lollipop again. The symptoms are the same as the last time this happened. Everything works except playback. Any time I try to play anything on the phone, the app crashes. Thanks
Luke 42244 Posted August 24, 2018 Posted August 24, 2018 Hi, would you mind downloading the different apk's from the last few weeks here and letting me know which one started the issue: https://github.com/MediaBrowser/Emby.Releases/commits/master/android/MediaBrowser.Mobile-googlearmv7-release.apk Thanks.
saj 14 Posted August 25, 2018 Author Posted August 25, 2018 Hi Luke, It appears the last release that worked was version 2.9.92 from March 12. The July 6th version 2.9.96 fails. I was having the same failure prior to version 2.9.92 for a few releases. You asked me to test that version, and it did fix the problem. Apparently version 2.9.96 reintroduced the issue. Thanks, Steve
