Guest asrequested Posted August 29, 2018 Posted August 29, 2018 (edited) That works fine. Currently using TV speakers Ok, hook up your optical and make it the default device, then try again. Run it as you would like it to be connected. Edited August 29, 2018 by Doofus
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 (edited) I will as soon as I can reboot to get my realtek audio back Wonder if this was a waste of time. Hope it doesn't bring other issues Edited August 29, 2018 by mentasm
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 I will as soon as I can reboot to get my realtek audio back Wonder if this was a waste of time. Hope it doesn't bring other issues I'm trying to find out where it's falling down. There have been so many updates to mpv, I'm trying to see where the breaking point is, if you don't mind helping me, that is?
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 OK, after installing most windows updates and updating the realtek software I seem to be back to working
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 OK, after installing most windows updates and updating the realtek software I seem to be back to working In Theater?
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 However, now I seem to have some horrible graphical glitches in ET
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 However, now I seem to have some horrible graphical glitches in ET Such as?
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 nevermind, restart of ET got rid of them. Thanks for your help
Ice 23 Posted August 29, 2018 Posted August 29, 2018 I noticed on your screenshots that windows was updating .Net versions, wasn't that an update that was needed a while back for Emby to run correctly?
Luke 42242 Posted August 29, 2018 Posted August 29, 2018 OK, after installing most windows updates and updating the realtek software I seem to be back to working Thanks for the feedback.
