Luke 42242 Posted August 28, 2018 Posted August 28, 2018 I would suggest making sure that windows is fully up to date. I would also configure audio settings in the app, making sure to only select pass-through formats that your audio hardware supports, and make sure that you've also completed the windows audio setup wizard.
mentasm 43 Posted August 28, 2018 Posted August 28, 2018 Audio was just set to auto. I don't do anything fancy. I just have a set of logitech speakers connected via optical. No special amplifiers or anything. This setup has worked for years as is.
Luke 42242 Posted August 28, 2018 Posted August 28, 2018 Try configuring it in Emby by explicitly setting the number of channels. It may not resolve anything but it is generally recommended. additionally if you have antivirus installed, perhaps it tampered with the install folder. Try disabling the Av and then install the app again.
mentasm 43 Posted August 28, 2018 Posted August 28, 2018 No AV installed. Not sure if windows 7 has an Audio setup wizard. Have tried setting 5.1 in audio
mentasm 43 Posted August 28, 2018 Posted August 28, 2018 (edited) I am now. To be honest I have kept this machine sitting without allowing updates for a very long time now. Got sick of them breaking my media center. Consequently the machine has run pretty much without fault for a long time now (years). What exactly is the requirement on windows updates that could break ET this bad? Did the latest MPV or electron has some specific requirements? Edited August 28, 2018 by mentasm
Guest asrequested Posted August 28, 2018 Posted August 28, 2018 Can you post a screenshot of your audio and video settings in Theater, and your windows audio config?
mentasm 43 Posted August 28, 2018 Posted August 28, 2018 not sure what you mean bt windows audio config. which screen
Guest asrequested Posted August 28, 2018 Posted August 28, 2018 not sure what you mean bt windows audio config. which screen If your're only using stereo, change that to stereo. And what does this look like on yours?
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 I have Realtek digital audio as my device. I think the screen you showed is supposed to be available from the configure button which you can see is not selectable
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 (edited) How is your cabling, configured? What cable goes from where to where? Edited August 29, 2018 by Doofus
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 Try selecting passthrough for AC3 and DTS
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 Tried that just then, no change in behaviour. Trying to find an more up to date version of the realtek software. Are you pretty sure this is audio stream related?
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 (edited) Tried that just then, no change in behaviour. Trying to find an more up to date version of the realtek software. Are you pretty sure this is audio stream related? No, I'm not. I'm trying to rule it out. An easy way to do that is, unplug the optical cable and try to play something. Edited August 29, 2018 by Doofus
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 Tried unplugging the optical. No change. Installed the latest realtek drivers I could fiund which has actually removed the realtek device pending reboot (stil installing windows updates so can't reboot for a bit) Default audio device is now my TV via HDMI. Have tried using that as well, and settign auto or 2.1 in ET audio settings. No change in behavior
Ice 23 Posted August 29, 2018 Posted August 29, 2018 (edited) I had a similar problem with my Logitech Z5500 speakers, but I think the real problem (for me anyway) is with using the Optical out, on this PC it is a little hit and miss, try using direct out/in so instead of using the Optical go back to the audio cables that came with the speakers. If I use HDMI audio direct to my screen there is no problem, I have a similar problem on my Emby server PC if I run Optical but on that I use HDMI out to the Amp then to the TV. I can still use Optical but not for everything, so I just use the direct out on this PC which still uses all 6 speakers. My problem is not directly Emby related it also effects my Hauppauge TV Tuner in this PC and my 2 DIVCO TV Tuners in the HT PC and has always been a problem. This PC Spec Win 10 Pro 64bit with latest updates (but had this problem with Win 7 Ultimate) CPU I7 8700K 32GB DDR4 3200 RAM GB GTX 1050Ti VGA Emby Server (HT PC) Win 7 Ultimate 64bit with latest updates CPU I7 7700 32GB DDR4 3200 RAM GB GTX 1050Ti VGA Edited August 29, 2018 by Ice
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 My config has been happily working in this configuration for a couple of years now. Its only the latest ET update that has broken things. Can I revert version and stay there? Pretty sure I can't
Ice 23 Posted August 29, 2018 Posted August 29, 2018 (edited) My config has been happily working in this configuration for a couple of years now. Its only the latest ET update that has broken things. Can I revert version and stay there? Pretty sure I can't Yes you can, I have always done manual updates, I have never let ET do auto updates, this is the 1st version I have had to delete the config files as well though, it will recreate them on 1st start which will take a little longer to start. I switched back and forth until I got 3.0.2 working correctly Edited August 29, 2018 by Ice
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 Where can I get the previous version and how do I stop auto updates?
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 I wouldn't recommend that. MPV has had many great improvements. Hang in the one sec. I'm gonna zip up an mpv standalone I'd like you to test with... brb
Ice 23 Posted August 29, 2018 Posted August 29, 2018 Where can I get the previous version and how do I stop auto updates? https://github.com/MediaBrowser/emby-theater-windows/releases
Guest asrequested Posted August 29, 2018 Posted August 29, 2018 Ok, unzip this anywhere you like. Double click on the mpv.exe and drag your video onto it.
mentasm 43 Posted August 29, 2018 Posted August 29, 2018 That works fine. Currently using TV speakers
