mohsinskynet 0 Posted August 23, 2018 Posted August 23, 2018 Need some custom css code to do that please help me someone 1: need to hide sync option from menu list 2: need to pull out download option from menu list 3: need to place a background for home menu for all users.
Happy2Play 9811 Posted August 23, 2018 Posted August 23, 2018 1. /*Remove Sync option*/ [data-id="sync"] {display: none !important;} 2. Not sure how to do this one. 3. Example from Blue Radiance Theme, add the url to your backdrop, Only Issue I see is it affects the Dashboard backdrop also. But should get you on the right track. div.backgroundContainer { background: url(bg.jpg) center top no-repeat #033361; -webkit-background-size: cover; background-size: cover; } 2
Solution bpbenich 10 Posted August 23, 2018 Solution Posted August 23, 2018 Yea.. I don't think you could do the second one with CSS. I think you'd have to edit the itemdetails.html file. 1
mgworek 134 Posted August 23, 2018 Posted August 23, 2018 unless you want them to be able to download on a mobile app, can't you just disable the download option for the each user?
mohsinskynet 0 Posted August 24, 2018 Author Posted August 24, 2018 (edited) TY YOU VERY MUCH FOR THAT PLEASE HELP ME FOR THE 2ND REQUEST I HAVE TO PULL OUT THE DOWNLOAD BUTTON LIKE PLAY BUTTON and one more thing the background is covering all the pages i want to cover only main home page Or dynamic backdrops ???? 1. /*Remove Sync option*/ [data-id="sync"] {display: none !important;} 2. Not sure how to do this one. 3. Example from Blue Radiance Theme, add the url to your backdrop, Only Issue I see is it affects the Dashboard backdrop also. But should get you on the right track. div.backgroundContainer { background: url(bg.jpg) center top no-repeat #033361; -webkit-background-size: cover; background-size: cover; } Edited August 24, 2018 by mohsinskynet
mohsinskynet 0 Posted August 27, 2018 Author Posted August 27, 2018 can it possible dynamic backdrops ??????? div.backgroundContainer {background: url(bg.jpg) center top no-repeat #033361;-webkit-background-size: cover;background-size: cover;} TY YOU VERY MUCH FOR THAT PLEASE HELP ME FOR THE 2ND REQUEST I HAVE TO PULL OUT THE DOWNLOAD BUTTON LIKE PLAY BUTTON and one more thing the background is covering all the pages i want to cover only main home page Or dynamic backdrops ????
Glen348 0 Posted August 30, 2018 Posted August 30, 2018 is custom css for premium users only, and is there any way to center the my media content boxes to the center instead of to the left
