cbek 0 Posted August 22, 2018 Posted August 22, 2018 Hello, I just updated EMBY to the lastest very on my QNAP TVS-EC880 and I did it as well with QMONO. 1- I have been surprised because my previous setup as not been kept. So I did the setup of the library agin. 2- My libraries are composed with DVD rip, it was working perfectly with the previous version but not anymore. I know that it's recommended to transform my DVD rip into MKV but it's to time consuming so in a short term, i would prefer to keep the DVD structure. Can you help me to anderstand why the libraray is empty in Emby ? Thanks, Cyril
Luke 42240 Posted August 22, 2018 Posted August 22, 2018 Hi, what does your folder structure look like?
cbek 0 Posted August 22, 2018 Author Posted August 22, 2018 The structure is : <movie name> —> <VIDEO_TS> —> <vob file>
cbek 0 Posted August 22, 2018 Author Posted August 22, 2018 Nothing! All the movie folders are directly in the share folder.
Luke 42240 Posted August 22, 2018 Posted August 22, 2018 Hmm, try adding an extra layer. See if that helps.
Solution cbek 0 Posted August 23, 2018 Author Solution Posted August 23, 2018 (edited) I found the solution.The proposed folder was "/share/CACHEDEV1_DATA/DVD" instead of "/share/DVD" Now, it's working! Thanks Edited August 23, 2018 by cbek
