jmariani 24 Posted August 22, 2018 Posted August 22, 2018 But no EmbyServer instance is running, at least is not shown on Activity Monitor. Had to reboot the machine.
Xennus 0 Posted January 5, 2019 Posted January 5, 2019 I was just getting the same thing. The EmbyServer process crashed on me with: Service exited due to signal: Segmentation fault: 11 sent by exc handler[0] When trying to restart Emby I was getting the same message as the OP in my logs. It ended up being due to the Electron process that EmbyServer launches still running. I quit it from Activity Monitor and then EmbyServer launched and is running correctly.
5stringdeath 0 Posted January 20, 2019 Posted January 20, 2019 (edited) It ended up being due to the Electron process that EmbyServer launches still running. I quit it from Activity Monitor and then EmbyServer launched and is running correctly. I don't have this process running, but I did have 3 instances (?) of Emby running after a graceful (I thought) shutdown from the web interface. Embyserver will not restart. I can't simply reboot this machine on demand as its doing other tasks. What's the proper solution? I can't even move emby to the trash as OSX tells me its running, but clearly activity monitor lists no active emby instance or "electron" which I've never seen. Edited January 20, 2019 by 5stringdeath
Luke 42239 Posted January 20, 2019 Posted January 20, 2019 There's an issue with the shutdown process on MacOS that we are currently looking into. If you run into this the easiest thing to do is reboot the machine. Thanks.
