jorgemeba 0 Posted August 21, 2018 Posted August 21, 2018 I’m using the emby app on my iPhone 6s and I’m trying to connect to chromecast, but is not showing as an available device. I tried it using different apps and it works, so is a problem with emby. Please help. Thank you.
jorgemeba 0 Posted August 21, 2018 Author Posted August 21, 2018 Hi, do you have any update on how to fix this problem? Thank you.
Luke 42147 Posted August 22, 2018 Posted August 22, 2018 Are you on the same wifi network as your chromecast?
jorgemeba 0 Posted August 22, 2018 Author Posted August 22, 2018 Yes, the cast works with other apps such as YouTube, but it doesn’t work with emby.
Luke 42147 Posted August 22, 2018 Posted August 22, 2018 Ok, in my testing it seems to be working fine, but i will continue to test this and see if I can find any issues. Thanks.
