nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) Got love SageTV this is one thing that dose better then everybody else with out deleting any tuners as it can remapping channels along side with mulit EPG on the fly because of it advanced features. It does not work with SageTV do you know something I don't ? I only had to map 19 OTA channels all others were picked up. Edited August 20, 2018 by nyplayer
hstamas 179 Posted August 20, 2018 Posted August 20, 2018 In my case I do not have that problem so it is a case by case bases.what are you using for your epg guide data @@nyplayer?
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) what are you using for your epg guide data @@nyplayer? In Emby Schedules Direct. They get the listings from Gracenote as does Silicondust. Edited August 20, 2018 by nyplayer
SHSPVR 125 Posted August 20, 2018 Posted August 20, 2018 (edited) It does not work with SageTV do you know something I don't ? I only had to map 19 OTA channels all others were picked up. Yes it not that hard to do let say you have a HDHomeRun Quatro you need just assign 3 tuner to local Cable EPG and leave the last tuner map to OTA EPG then from channel setup you can remap channel 2.1, 2.2, 2.3 to all the OTA channel from the local Cable EPG feed because I'm sure some of the OTA channel are not on Cable EPG. But I recommend just add another HDHomeRun Quatro and assign 4 tuner to local Cable EPG and leave one of the HDHomeRun Quatro assign to the OTA channel. I think but no 100% sure with Emby you be able used mulit HDHomeRun device and just assign one to Cable EPG and other device to OTA EPG feed Edited August 20, 2018 by SHSPVR
clarkss12 304 Posted August 20, 2018 Posted August 20, 2018 In Emby Schedules Direct. They get the listings from Gracenote as does Silicondust. I followed your instructions from your previous post, but my guide is spotty. Some on the new channels have data, but about half don't. Also, how did you map your OTA channels... Thanks
SHSPVR 125 Posted August 20, 2018 Posted August 20, 2018 I followed your instructions from your previous post, but my guide is spotty. Some on the new channels have data, but about half don't. Also, how did you map your OTA channels... Thanks he used what ever was available from the Cable EPG
garyan2 53 Posted August 20, 2018 Posted August 20, 2018 Why not just add the OTA lineup as well as the cable lineup? Wouldn't everything get automapped then? You can have up to 4 lineups.
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 he used what ever was available from the Cable EPG Correct
hstamas 179 Posted August 20, 2018 Posted August 20, 2018 In Emby Schedules Direct. They get the listings from Gracenote as does Silicondust. Hmm. I wonder why some people are having issues over on the SD forums? Possibly the feeds you receive depends on where in the country you live?
SHSPVR 125 Posted August 20, 2018 Posted August 20, 2018 Why not just add the OTA lineup as well as the cable lineup? Wouldn't everything get automapped then? You can have up to 4 lineups. Doesn't work that way as there assign per device how ever Luke could change the way that works
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 Why not just add the OTA lineup as well as the cable lineup? Wouldn't everything get automapped then? You can have up to 4 lineups. can you assign multiple lineups to 1 Device ?
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) Doesn't work that way as there assign per device how ever Luke could change the way that works Glad to see you on here … I think you might be able to use OPENDCT to tune these channels in SageTV Edited August 20, 2018 by nyplayer
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) Hmm. I wonder why some people are having issues over on the SD forums? Possibly the feeds you receive depends on where in the country you live? Probably … I know when they first offered it I compared the 50 or so channels to what was on Cable and they all checked out with the right times. I did before it was officially released. Edited August 20, 2018 by nyplayer
clarkss12 304 Posted August 20, 2018 Posted August 20, 2018 he used what ever was available from the Cable EPG Can you give me a little more specifics on how to map the OTA channels???? thanks
garyan2 53 Posted August 20, 2018 Posted August 20, 2018 can you assign multiple lineups to 1 Device ?I don't see why not. When adding a lineup there is an option to "Enable for all tuner devices" which is default TRUE. I guess I am not understanding what that means for individual tuners.
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) I don't see why not. When adding a lineup there is an option to "Enable for all tuner devices" which is default TRUE. I guess I am not understanding what that means for individual tuners. Trying that now looks like you are right. Hey that worked and Channels were mapped automatically. Edited August 20, 2018 by nyplayer
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) Conclusion what worked for me. Comcast 97217 Added the Quatro ... Setup Guide data for OTA and Cable. (schedules Direct) Pointed Quatro to both Listings OTA and Cable. (Thanks garyan2,) Channels Mapped correctly (automatically) Able to record and play channels in EMBY. Edited August 20, 2018 by nyplayer
SHSPVR 125 Posted August 20, 2018 Posted August 20, 2018 (edited) Can you give me a little more specifics on how to map the OTA channels???? thanks Go to Server Dashboard then LiveTV you see Schedules Direct then you should see ... click and map channel you see the pencil icon that how you edit in Emby from there you can remap the channel Or did you mean SageTV ?. Edited August 20, 2018 by SHSPVR
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 (edited) For those having problems and use Schedules direct make sure on schedules direct you have both an OTA and Cable lineup... for your area. Edited August 20, 2018 by nyplayer
clarkss12 304 Posted August 20, 2018 Posted August 20, 2018 (edited) Go to Server Dashboard then LiveTV you see Schedules Direct then you should see ... click and map channel you see the pencil icon that how you edit in Emby from there you can remap the channel Or did you mean SageTV ?. Ok, thanks, that was my question. I did not "see" those 3 little dots on the side. Now I will do some mapping. Edit: As I try to **map** my broadcast channels, I don't see the sub-channels to map....... What am I missing? Edited August 20, 2018 by clarkss12
clarkss12 304 Posted August 20, 2018 Posted August 20, 2018 For those having problems and use Schedules direct make sure on schedules direct you have both an OTA and Cable lineup... for your area. Yes, I had that part. But a lot of the guide data did not show up. I will try some re-mapping.
jasonmcroy 320 Posted August 20, 2018 Posted August 20, 2018 For those of you that are re-mapping your channels - do your channel logos change as well? I just spent about 15 minutes re-mapping but the logo stays the same even though the guide data is now correct.
nyplayer 90 Posted August 20, 2018 Author Posted August 20, 2018 Ok, thanks, that was my question. I did not "see" those 3 little dots on the side. Now I will do some mapping. Edit: As I try to **map** my broadcast channels, I don't see the sub-channels to map....... What am I missing? Did you add a cable and ota lineup to the tuner ?
SHSPVR 125 Posted August 20, 2018 Posted August 20, 2018 (edited) Ok, thanks, that was my question. I did not "see" those 3 little dots on the side. Now I will do some mapping. Edit: As I try to **map** my broadcast channels, I don't see the sub-channels to map....... What am I missing? You need have more then one device then besure that Enable for all tuner devices is check For example you one are pair of dual or quatro assign one device to an OTA EPG and 2nd device to a your local Cable EPG or just add 2nd Schedules Direct that point to your local cable The remap both to properly match the across the device check and uncheck and remap to corresponding TV broadcast provider Edited August 20, 2018 by SHSPVR
clarkss12 304 Posted August 20, 2018 Posted August 20, 2018 Did you add a cable and ota lineup to the tuner ? Yes.
