otispresley 112 Posted August 21, 2018 Posted August 21, 2018 Yesterday, I was demo'ing the Premium TV service https://www.silicondust.com/premium-tv/ from SiliconDust and discovered that there is no one guide source on Scheduled Direct that has all my channels now since some are OTA and the rest are Cable. Would it be possible to pull data from multiple guides and allow people to map their channels using data from all the lineups?
Sammy 791 Posted August 21, 2018 Posted August 21, 2018 (edited) Yes. This feature already exists. In Server Management > Tuner Devices > TV Guide Data Providers.. Add another guide. I used att Uverse but am probably going to try again with Comcast. It is not near my area but the numbering more closely aligns and less mapping will be needed. My issue currently is that the guide logos are not quite right. Still working a solution but since Emby allows multiple guide data providers it is better than Plex which only allows one. Now if it would only allow channel number re-mapping. Edited August 21, 2018 by Sammy
Sammy 791 Posted August 21, 2018 Posted August 21, 2018 @@Luke As this is not a needed new feature and already exists, I request it be put in the Live TV section. Thanks!
otispresley 112 Posted August 21, 2018 Author Posted August 21, 2018 Ahhh, ok. Thanks for the clarification! I did not know you could add Schedules Direct twice and did not think of it. 1
Sammy 791 Posted August 21, 2018 Posted August 21, 2018 Ahhh, ok. Thanks for the clarification! I did not know you could add Schedules Direct twice and did not think of it. Yes, You can have up to four different guide data providers and then tweak as needed using the mapping function. Very slick! This is because some people have both OTA tuners and CableCARD tuners and it allows one to have a merged guide. Comes in handy here too.
Carlo 4561 Posted August 22, 2018 Posted August 22, 2018 Another possibility is what I do and that is to use WebGrab+Plus to pull EPG data from different sources (including free sources). Using this method you can build separate EPG files or a combined file that can be used for OTA, Cable and IPTV sources. I currently build 3 files (OTA, Cable, IPTV) to cover the sources I use. I might split out the HDHomeRun Premium TV to a 4th source since it's unique. Carlo
mlcarson 13 Posted August 23, 2018 Posted August 23, 2018 Is there any way to do a null mapping. My experience has been with Schedules Direct that it uses the channel number no matter what. You can't remove a mapping that automatches. So, I've been using a layered approach by using other EPG sources first since it appears that the first match wins.
Luke 42244 Posted August 23, 2018 Posted August 23, 2018 Not at that time but we'll be redoing our channel management in the near future. thanks. 1
