makarai 109 Posted August 31, 2018 Posted August 31, 2018 Also what version of freebsd are you on? 11.2
Luke 42239 Posted August 31, 2018 Posted August 31, 2018 So that's interesting that you're able to successfully install but @@embytal is not.
embytal 3 Posted August 31, 2018 Author Posted August 31, 2018 So that's interesting that you're able to successfully install but @@embytal is not. To be precise the installation is successful in my case. The playback of anything fails. Continuing to troubleshoot now trying to identify useful information. Will report soon 1
embytal 3 Posted August 31, 2018 Author Posted August 31, 2018 @@embytal You can't just run the ffmpeg binary like that, our libraries are not in a standard directory so they won't be discovered unless you export LD_LIBRARY_PATH first. Of course the emby launcher script does that for you. export LD_LIBRARY_PATH=/usr/local/opt/emby-server/bin Are you able to manually run the ffmpeg binary after you do this? When I try in my jail: root@emby:/var/db/emby-server/logs # export LD_LIBRARY_PATH=/usr/local/opt/emby-server/bin export: Command not found. From the logs I have that: 018-08-31 16:17:42.784 Error App: Error in ffprobe *** Error Report *** Version: 3.6.0.31 Command line: /usr/local/opt/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/opt/emby-server/bin/ffmpeg -ffprobe /usr/local/opt/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.2.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (5.10.1.47 Tue Aug 28 02:52:32 UTC 2018) Processor count: 16 Program data path: /var/db/emby-server Application directory: /usr/local/opt/emby-server/system System.Exception: ffprobe failed for file:"/mnt/Media/Movies/mymovie.mkv" - streams and format are both null. at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x001d4] in <c9e5e914e4a24f7982a3cf49bd11b489>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x00369] in <c9e5e914e4a24f7982a3cf49bd11b489>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo+<ProbeVideo>d__16`1[T].MoveNext () [0x002a8] in <f91bd2b8525c4e678f52cc1e30b416e9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.Manager.MetadataService`2+<RunCustomProvider>d__36[TItemType,TIdType].MoveNext () [0x000d9] in <f91bd2b8525c4e678f52cc1e30b416e9>:0 System.Exception at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x001d4] in <c9e5e914e4a24f7982a3cf49bd11b489>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at Emby.Server.MediaEncoding.Encoder.MediaEncoder+<GetMediaInfoInternal>d__69.MoveNext () [0x00369] in <c9e5e914e4a24f7982a3cf49bd11b489>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo+<ProbeVideo>d__16`1[T].MoveNext () [0x002a8] in <f91bd2b8525c4e678f52cc1e30b416e9>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0 at MediaBrowser.Providers.Manager.MetadataService`2+<RunCustomProvider>d__36[TItemType,TIdType].MoveNext () [0x000d9] in <f91bd2b8525c4e678f52cc1e30b416e9>:0 And it keeps going on as the web player continues to try playing the movie but nothing works.
alucryd 318 Posted September 1, 2018 Posted September 1, 2018 My bad, forgot that freebsd has csh as their default shell (the launcher script is using regular sh), the right command is: setenv LD_LIBRARY_PATH /usr/local/opt/emby-server/lib Running ffmpeg after that should tell us if it's an issue with ffmpeg or your files. Does the emby user have read access to your files? Can you share one that is failing so we can know what kind of codecs are used inside?
embytal 3 Posted September 1, 2018 Author Posted September 1, 2018 (edited) My bad, forgot that freebsd has csh as their default shell (the launcher script is using regular sh), the right command is: setenv LD_LIBRARY_PATH /usr/local/opt/emby-server/lib Running ffmpeg after that should tell us if it's an issue with ffmpeg or your files. Does the emby user have read access to your files? Can you share one that is failing so we can know what kind of codecs are used inside? Alright I think I found the issue ! Here is what I have: root@emby:~ # setenv LD_LIBRARY_PATH /usr/local/opt/emby-server/lib root@emby:~ # /usr/local/opt/emby-server/bin/ffmpeg Shared object "libx264.so.152" not found, required by "libavcodec.so.58" Checking the lib folder, it does not come with emby (which is expected) root@emby:~ # ls -lai /usr/local/opt/emby-server/lib total 10844 122187 drwxr-xr-x 2 root wheel 32 Aug 30 23:55 . 122183 drwxr-xr-x 5 root wheel 5 Aug 30 23:55 .. 122188 lrwxr-xr-x 1 root wheel 18 Jul 9 10:53 libSkiaSharp.so -> libSkiaSharp.so.60 122189 lrwxr-xr-x 1 root wheel 22 Jul 9 10:53 libSkiaSharp.so.60 -> libSkiaSharp.so.60.0.0 122190 -rw-r--r-- 1 root wheel 4486136 Jul 9 10:53 libSkiaSharp.so.60.0.0 122191 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavcodec.so -> libavcodec.so.58.18.100 122192 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavcodec.so.58 -> libavcodec.so.58.18.100 122193 -rw-r--r-- 1 root wheel 7832256 Aug 3 11:54 libavcodec.so.58.18.100 122194 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavdevice.so -> libavdevice.so.58.3.100 122195 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavdevice.so.58 -> libavdevice.so.58.3.100 122196 -rw-r--r-- 1 root wheel 73040 Aug 3 11:54 libavdevice.so.58.3.100 122197 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavfilter.so -> libavfilter.so.7.16.100 122198 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavfilter.so.7 -> libavfilter.so.7.16.100 122199 -rw-r--r-- 1 root wheel 2826856 Aug 3 11:54 libavfilter.so.7.16.100 122200 lrwxr-xr-x 1 root wheel 24 Aug 3 11:54 libavformat.so -> libavformat.so.58.12.100 122201 lrwxr-xr-x 1 root wheel 24 Aug 3 11:54 libavformat.so.58 -> libavformat.so.58.12.100 122202 -rw-r--r-- 1 root wheel 2494512 Aug 3 11:54 libavformat.so.58.12.100 122203 lrwxr-xr-x 1 root wheel 22 Aug 3 11:54 libavutil.so -> libavutil.so.56.14.100 122204 lrwxr-xr-x 1 root wheel 22 Aug 3 11:54 libavutil.so.56 -> libavutil.so.56.14.100 122205 -rw-r--r-- 1 root wheel 440304 Aug 3 11:54 libavutil.so.56.14.100 122206 lrwxr-xr-x 1 root wheel 19 Jul 17 06:16 libmp3lame.so -> libmp3lame.so.0.0.0 122207 lrwxr-xr-x 1 root wheel 19 Jul 17 06:16 libmp3lame.so.0 -> libmp3lame.so.0.0.0 122208 -rw-r--r-- 1 root wheel 264280 Jul 17 06:16 libmp3lame.so.0.0.0 122209 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libpostproc.so -> libpostproc.so.55.1.100 122210 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libpostproc.so.55 -> libpostproc.so.55.1.100 122211 -rw-r--r-- 1 root wheel 116688 Aug 3 11:54 libpostproc.so.55.1.100 122212 lrwxr-xr-x 1 root wheel 24 Aug 3 11:54 libswresample.so -> libswresample.so.3.1.100 122213 lrwxr-xr-x 1 root wheel 24 Aug 3 11:54 libswresample.so.3 -> libswresample.so.3.1.100 122214 -rw-r--r-- 1 root wheel 120784 Aug 3 11:54 libswresample.so.3.1.100 122215 lrwxr-xr-x 1 root wheel 21 Aug 3 11:54 libswscale.so -> libswscale.so.5.1.100 122216 lrwxr-xr-x 1 root wheel 21 Aug 3 11:54 libswscale.so.5 -> libswscale.so.5.1.100 122217 -rw-r--r-- 1 root wheel 538576 Aug 3 11:54 libswscale.so.5.1.100 I have the package installed as per the required list of packages: root@emby:~ # pkg info -x x264 libx264-0.155.2917 And the more verbose output shows it: root@emby:~ # pkg info libx264 libx264-0.155.2917 Name : libx264 Version : 0.155.2917 Installed on : Thu Aug 30 23:54:42 2018 EDT Origin : multimedia/libx264 Architecture : FreeBSD:11:amd64 Prefix : /usr/local Categories : multimedia Licenses : GPLv2 Maintainer : koobs@FreeBSD.org WWW : http://www.videolan.org/x264.html Comment : H.264/MPEG-4 AVC Video Encoding (Library) Options : ASM : on DEBUG : off GCC : off OPENCL : on PGO : off Shared Libs provided: libx264.so.155 Annotations : FreeBSD_version: 1101001 repo_type : binary repository : FreeBSD Flat size : 4.67MiB Description : x264 is a free library for encoding H.264/AVC (aka MPEG-4 Part 10) video streams. Encoder features * CAVLC/CABAC * Multi-references * Intra: all modes (4x4 and 16x16 with all predictions) * Inter P: all partitions (from 16x16 down to 4x4) * Inter B: partitions from 16x16 down to 8x8 (including SKIP/DIRECT) * Ratecontrol: constant quantizer, constant bitrate, or multipass ABR * Scene cut detection WWW: http://www.videolan.org/x264.html It looks like your custom package has no link to the latest version of that lib. I grab the required packages from FreeBSD latest packages and not quarterly. The version from quarterly is 0.152.2854. Recreating my jail on quarterly packages makes everything works so I can confirm in this version, I have the fix for ScheduleDirect pulling things down for my OTA guide and obviously there is no playback error anymore. If you look at this libx264 package, there was an update on the 10th of August 2018 (which I hadn't checked before). https://www.freshports.org/multimedia/libx264/ I would highly recommend you add a clear note on your FreeBSD instructions page for old timers like me who like being on the latest and greatest and may use the latest version of packages. It might be good to keep track of the version of packages somewhere against the version of the package on your github. I will continue validating Emby but it is very promising as Plex gave me the feeling of being boxed in their ecosystem. Thank you all for your support. Edited September 1, 2018 by embytal 1
Luke 42239 Posted September 1, 2018 Posted September 1, 2018 But why does it cause a failure to not be on the very latest?
embytal 3 Posted September 1, 2018 Author Posted September 1, 2018 (edited) But why does it cause a failure to not be on the very latest? Because there seems to be a link to a precise x264 library version instead of a generic name that would have symlink to the latest version a bit like what you have currently for some embedded emby libs: 122191 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavcodec.so -> libavcodec.so.58.18.100 122192 lrwxr-xr-x 1 root wheel 23 Aug 3 11:54 libavcodec.so.58 -> libavcodec.so.58.18.100 122193 -rw-r--r-- 1 root wheel 7832256 Aug 3 11:54 libavcodec.so.58.18.100 So here ideally there should be a linked library to libx264.so and the necessary symlinks. I am not the expert on this one, but it looks more like missing links somewhere rather than the version of that lib not working, until the linkage can be fixed and a formal test can be done. Edited September 1, 2018 by embytal
Luke 42239 Posted September 1, 2018 Posted September 1, 2018 So you basically ran the dependency install command again, right?
embytal 3 Posted September 1, 2018 Author Posted September 1, 2018 So you basically ran the dependency install command again, right? Nope. I confirm there is a hard dependency on installing the quarterly packages for the BETA version to have the right library. The BETA version has a problem with playback which does not work at all on the latest version of libx264 and I do not know how to fix that. I have a fresh jail based on quarterly packages instead of latest packages and Emby playback works fine. In a few weeks from now, this BETA will not work when the version of libx264 will be distributed as version 155 instead of 152 when the next FreeBSD package update will happen for quarterly.
Luke 42239 Posted September 2, 2018 Posted September 2, 2018 So you didn't follow the install instructions?
embytal 3 Posted September 2, 2018 Author Posted September 2, 2018 (edited) So you didn't follow the install instructions? Did you read my answer where I explained the problem I faced and recommend for somebody to modify the instructions to make sure it refers to use quarterly packages instead of latest (that's something that is configurable on FreeBSD)? That is to make the beta work. That does not solve the problem I faced with the lib x264 v155 which does not seem to be linked properly. Edited September 2, 2018 by embytal
alucryd 318 Posted September 2, 2018 Posted September 2, 2018 @@embytal Wasn't aware freebsd had 2 release cycles, I installed my VM with default settings to build our ffmpeg. @@Luke He can't follow our instructions to the letter because our ffmpeg is built against the libraries found in the quarterly release of freebsd, this release has older (and arguably more stable) versions of the libraries we link against so most of the time our current ffmpeg won't work with the latest release without dowgrading some packages.
embytal 3 Posted September 2, 2018 Author Posted September 2, 2018 @@embytal Wasn't aware freebsd had 2 release cycles, I installed my VM with default settings to build our ffmpeg. To be precise, it is not a release cycle as such but more a decision from the FreeBSD team to increase the stability by being on mature versions of packages. It is fairly recent though: https://www.freebsd.org/releases/10.2R/relnotes.html - point 12.1 all the way at the bottom of the page. The main challenge with quarterly is that I don't believe there is a set date for releasing them while latest are generally coming on Wednesdays on a weekly basis. So while quarterly is the new default, a lot of people want to work with latest version of packages, mainly from habit and are likely to pull latest instead of quarterly.
Luke 42239 Posted September 2, 2018 Posted September 2, 2018 What a mess. If I'm understanding that right, that means no matter what we choose there will be a group of users running into this.
embytal 3 Posted September 2, 2018 Author Posted September 2, 2018 What a mess. If I'm understanding that right, that means no matter what we choose there will be a group of users running into this. Not if there is a clear reference on Emby website of the required version of packages then it is on the users to get that right.
sluggo45 47 Posted September 3, 2018 Posted September 3, 2018 Cross-referencing my post in the FreeNAS package thread: https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/page-7&do=findComment&comment=615883 - a temp fix, if you don't already know, is compile ffmpeg from the port with the correct options and change the Emby startup script paths to use it instead. Works. I was having the same issues as this thread though I originally discovered them because the Roku thumbs addon wasn't working.
Luke 42239 Posted September 3, 2018 Posted September 3, 2018 Well for now that works but it is looking extremely likely what we will soon be adding our own code changes to ffmpeg for new features and improvements. So we will need to be able to build our own. So based on this, everyone's feedback will be helpful about whether we should build against freebsd latest or freebsd stable. Whichever one we choose, there will be one crowd of people having a problem so I guess we need to figure out which crowd will be larger.
embytal 3 Posted September 3, 2018 Author Posted September 3, 2018 (edited) Well for now that works but it is looking extremely likely what we will soon be adding our own code changes to ffmpeg for new features and improvements. So we will need to be able to build our own. So based on this, everyone's feedback will be helpful about whether we should build against freebsd latest or freebsd stable. Whichever one we choose, there will be one crowd of people having a problem so I guess we need to figure out which crowd will be larger. Or you can clearly state in your documentation which version you put as a requirement. If you want to know more about the schedule of port/package update on quarterly for FreeBSD you should look at this wiki: https://wiki.freebsd.org/Ports/QuarterlyBranch This is the default in FreeBSD, you can decide for the stable release to be dependent on quarterly to keep the pace of update under control while your BETA version could be on latest. Regardless, I would modify the current page to make sure it states explicitly the recommended version of packages being used. You are likely to people do the same as I did under FreeNAS through jails which uses the same base as FreeBSD. Hope that helps. Edited September 3, 2018 by embytal
Luke 42239 Posted September 3, 2018 Posted September 3, 2018 Thanks for the info, yes we'll improve documentation about this, thanks.
sluggo45 47 Posted September 3, 2018 Posted September 3, 2018 (edited) I agree, with the caveat that if the stable Emby train is on quarterly and the beta train requires latest things will get messy....documentation will help from a "RTFM" perspective I suppose Users will be running Emby in a jail, most likely one dedicated to Emby. Requiring quarterly packages doesn't seem like a big stretch. Unless I am forgetting something, which package train you are on is jail-specific. Edited September 3, 2018 by sluggo45 1
Luke 42239 Posted September 3, 2018 Posted September 3, 2018 I think it's going to be the same for both. It will be easier on our build server as well as the testing process for both us and users.
Johnsz 0 Posted October 12, 2018 Posted October 12, 2018 A fresh freebsd 11.2 install following the instructions on the installation page both 3.5.3.0 and the BETA , can't play files . It throws ffmpeg errors mentioned in this thread. The install worked last week. Any easy fix ?
Luke 42239 Posted October 12, 2018 Posted October 12, 2018 Make sure you have configured your freebsd environment to use stable packages and not latest. Thanks.
Johnsz 0 Posted October 12, 2018 Posted October 12, 2018 I just tried pkg install emby-server instead and it worked. Thanks.
