Quiffster 1 Posted August 20, 2018 Posted August 20, 2018 Hi - Updated to 3.5.2 today. Restarted the service and get the attached logon screen (which doesn't accept any credentials)??? Strangely - Straight after an install - if I click to configure emby from the app in notification area (I.e. not as a service) - the main emby page shows up ok. Indeed, when started like this - accessing the url across the network shows the proper emby profile selection pages too. I notice the url slightly changed: from: http://localhost:8096/emby/web/.... to: http://localhost:8096/web/....... Restarting as a service, using new url works ok too. Assume old url structure is gone and this is intentional, and I should tell everyone to update bookmarks?
Quiffster 1 Posted August 20, 2018 Author Posted August 20, 2018 One more thing, maybe related.. AutoOrganize plugin won't update. Uninstalled it, reinstalled it, and it won't install anymore..???
ryandavidg 30 Posted August 20, 2018 Posted August 20, 2018 (edited) The URLs did change slightly a few months ago, also caused me some problems until I worked it out (can't make out what you specified above but they went from app.emby.media/ to app.emby.media/#!/ for all relevant URLs). Not sure why there wasn't an announcement about it given how many of us probably use bookmarked or remembered URLs. Edited August 20, 2018 by ryandavidg
Luke 42212 Posted August 20, 2018 Posted August 20, 2018 Yes some urls have changed. The easiest thing to do is just bookmark the front portion: http://localhost:8096 That's all you need. Thanks.
Luke 42212 Posted August 20, 2018 Posted August 20, 2018 One more thing, maybe related.. AutoOrganize plugin won't update. Uninstalled it, reinstalled it, and it won't install anymore..??? Why do you feel that it won't install? What happens when you try to install it?
