anthony.lemoine 0 Posted November 2, 2018 Posted November 2, 2018 re bonjour, when do you expect an update ? I prefer more emby than plex ; emby is top ! lol merci. bien à toi. anthony.
Lazarus_Long 80 Posted November 2, 2018 Posted November 2, 2018 Brand new Emby user here and the first thing I noticed on my Android tablet is significant lag between audio and video when using BT headphones and downloaded content. Will try a few others things and report back.
saitoh183 137 Posted November 9, 2018 Posted November 9, 2018 @@Luke I have the same issue but i noticed that it is only with the Android for Emby. If i use the Web via my android device, the audio isnt out of sync
rhodges 49 Posted November 19, 2018 Posted November 19, 2018 I, too, have audio sync issues with 3.0.21 using the built in player and bluetooth. If I use an external player, I don't have any out of sync issues. The audio is a second or so late.
Luke 42245 Posted November 19, 2018 Posted November 19, 2018 Please try again with the next update to the app. Thanks !
anthony.lemoine 0 Posted November 19, 2018 Posted November 19, 2018 merci. when do you upload the next update, Luke ? merci.
lhorace 1 Posted November 24, 2018 Posted November 24, 2018 Hello, I'm glad I came across this thread because for second there, I was under the assumption it was my under-powered Android device. I've been using VLC in-place of Emby Android Player, that is, when VLC is able to locate and load my library properly. 1
troyhough 61 Posted November 29, 2018 Posted November 29, 2018 Hopefully soon. Beta or Official release?
Jdiesel 1437 Posted November 29, 2018 Posted November 29, 2018 I just did a quick test and can confirm this. Samsung s8+ Skullcandy bluetooth headphones Emby 3.0.21 Video was direct playing Media info of the video is Media Info Video Title480p H264 CodecH264 AVCYes ProfileHigh Level41 Resolution852x480 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate1,583 kbps Color primariesbt709 Color spacebt709 Color transferbt709 Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio TitleEng Dolby Digital stereo Default Languageeng CodecAC3 Layoutstereo Channels2 ch Bitrate192 kbps Sample rate48,000 Hz DefaultYes Containermkv 1
troyhough 61 Posted December 19, 2018 Posted December 19, 2018 (edited) The Bluetooth headphone delay appears fixed (3.0.24), however playing through the phone speakers is now out of sync. Grrrrrrr! Edited December 21, 2018 by troyhough
Luke 42245 Posted December 21, 2018 Posted December 21, 2018 @@AdrianW are you able to reproduce this?
troyhough 61 Posted December 21, 2018 Posted December 21, 2018 (edited) @@AdrianW are you able to reproduce this? Im not Adrian, however, I can confirm that audio is out of sync on LAN and over LTE, for both Live TV and recorded content on the phone speaker. I am using the Pixel 2 XL. Edit on Dec 24th: Betas 3.0.25 and 3.0.26 have since been pushed out and both are still out of sync, just an FYI. Edited December 24, 2018 by troyhough
imthedoctor 7 Posted December 24, 2018 Posted December 24, 2018 (edited) Any update to this, the version posted to "try" this makes headphone jack audio out of sync on my phone, any fix for this yet? Edited December 24, 2018 by imthedoctor
troyhough 61 Posted December 24, 2018 Posted December 24, 2018 I'm still having issues on the recent betas, 3.0.25 and 3.0.26
Bomsterr 4 Posted December 25, 2018 Posted December 25, 2018 I'm also getting audio sync issues on the 3.0.26 app, it was happening on all video files I tried.
Chyron 256 Posted December 26, 2018 Posted December 26, 2018 (edited) Emby for Android v3.0.26 Android 8.0.0 Oreo Moto Z Play Droid XT1635-01 I also have noticed this, tried on multiple files. Audio stream is out of sync, noticeably ahead of video stream by a fraction of a second. One file played fine: Media Info VideoTitle480P MPEG4CodecMPEG4Codec tagXVIDProfileAdvanced Simple ProfileLevel5Resolution672x512Aspect ratio4:3InterlacedNoFramerate29.97003Bitrate812 kbpsPixel formatyuv420pRef frames1 AudioTitleMP3 stereoCodecMP3LayoutstereoChannels2 chBitrate128 kbpsSample rate48000 HzDefaultNoContaineravi Other files have audio delay, whether transcoding, direct, or downloaded. Same files confirmed no delay on Web app. Media Info VideoTitle720P H264CodecH264AVCYesProfileHighLevel41Resolution960x720Aspect ratio4:3InterlacedNoFramerate23.9760246Bitrate816 kbpsColor primariesbt709Color spacebt709Color transferbt709Bit depth8 bitPixel formatyuv420pRef frames1NAL4 AudioTitleEng AAC stereo DefaultLanguageengCodecAACProfileLCLayoutstereoChannels2 chBitrate192 kbpsSample rate48000 HzDefaultYesSubtitleTitleEng DefaultLanguageengCodecSUBRIPDefaultYesForcedNoExternalNoContainermkv --- Media Info VideoTitle480P H264CodecH264Codec tagavc1AVCYesProfileMainLevel31Resolution720x390Aspect ratio1.85:1InterlacedNoFramerate23.9762135Bitrate892 kbpsColor primariessmpte170mColor spacesmpte170mColor transferbt709Bit depth8 bitPixel formatyuv420pRef frames1NAL4 AudioTitleUnd AAC stereo DefaultLanguageundCodecAACCodec tagmp4aProfileLCLayoutstereoChannels2 chBitrate160 kbpsSample rate48000 HzDefaultYesContainermov Edited December 26, 2018 by chyron8472 1
troyhough 61 Posted December 26, 2018 Posted December 26, 2018 I received 3.0.27 today. Delay still there.
bassistgak 6 Posted December 30, 2018 Posted December 30, 2018 Confirmed, still there Pixel 3. latest emby release Headphone jack (via usb C as no headphone jack on Pixel 3) no sync issues. Bluetooth has significant audio delay.
