Luke 42244 Posted August 30, 2018 Posted August 30, 2018 Can you guys try this version? https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks !
koldfuzion 1 Posted August 30, 2018 Posted August 30, 2018 This latest version appears to fix the sync issue. I tested a few different formats and everything looks good so far for me. Thanks for the prompt fix. 1
rahul65 1 Posted August 30, 2018 Posted August 30, 2018 Yep this fixes the issue for the most part.. I will let you know of somehow if i find the issue again.Thank you so much. 1
RedNuttyGuy 1 Posted August 30, 2018 Posted August 30, 2018 looking pretty good. keep up the good work you guys! Love this software, as do all my mates lol 1
AdrianW 1058 Posted August 31, 2018 Author Posted August 31, 2018 So, it's now fine with wired earphones - but when I use my bluetooth earphones the audio delay is significant. Using the same earphones with another video player and the delay is unnoticeable. I realise that the audio has to be re-encoded at some point to be sent to the earphones.
Luke 42244 Posted August 31, 2018 Posted August 31, 2018 Can you re-confirm with this version: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 I'd like to push this to the store. Thanks !
RedNuttyGuy 1 Posted August 31, 2018 Posted August 31, 2018 Can you re-confirm with this version: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 I'd like to push this to the store. Thanks ! Honestly, it feels even a little better but that might just be me. Regardless I can't see any issues.
AdrianW 1058 Posted September 1, 2018 Author Posted September 1, 2018 I'd like to push this to the store. Thanks ! It's OK for wired earphones - but terrible for bluetooth, there's a significant audio delay - even when playing video with 2 channel AAC audio which I would assume shouldn't need any re-encoding to be sent over bluetooth.
planedrop 4 Posted September 2, 2018 Posted September 2, 2018 Can you re-confirm with this version: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 I'd like to push this to the store. Thanks ! Just wanted to confirm you pointed me here from another thread, this version works perfectly for me as well. Thank you!
AdrianW 1058 Posted September 4, 2018 Author Posted September 4, 2018 I had the dropbox version (posted here) which was working OK. But, a new version downloaded from the PlayStore last night - which appears to be broken. I have it offline and going to "Latest Downloaded Videos" and clicking on any of the videos in the list or the last panel (coloured "TV") will start the circle spinning again and then after waiting for the 20 seconds I'm returned to the Select Server screen. So, I can no longer play anything.
Luke 42244 Posted September 4, 2018 Posted September 4, 2018 Seems to be OK in my testing. There is probably some other explanation as the builds are just about identical.
AdrianW 1058 Posted September 5, 2018 Author Posted September 5, 2018 Seems to be OK in my testing. There is probably some other explanation as the builds are just about identical. I can now start playback after restarting my phone.
anthony.lemoine 0 Posted October 26, 2018 Posted October 26, 2018 hello, i have a media pad m5, emby server on hetzner server : xeon e3-1246, download speed on hetzner : 1gbits. At home i have a wifi at 50mbits (VDSL2) i watch series on my mediapad m5 with emby for android 3.0.21 with bluethooh plantronics blackbeat pro 2. and : the video and sound are not synchonized : ~1s de lag Can you help me ? Thanks. Merci Anthony.
Luke 42244 Posted October 26, 2018 Posted October 26, 2018 Hi, if you play without bluetooth, how does it sound?
anthony.lemoine 0 Posted October 26, 2018 Posted October 26, 2018 hello, mediapad m5 have only bluetooth. Merci.
anthony.lemoine 0 Posted November 1, 2018 Posted November 1, 2018 hello, no lag without bluetooth, but lag with emby and bluethooth
anthony.lemoine 0 Posted November 2, 2018 Posted November 2, 2018 Bonjour Luke, There is a lag between video and sound, but this is a very little lag. merci. Mediapad 10.8 android 8.0 and plantonics bluethooth headset / emby for android.
