VTMarik 0 Posted August 20, 2018 Posted August 20, 2018 I'm attempting to get metadata for Ultraman the television series, but no matter what I do emby keeps grabbing the data for the Ultraman anime despite me erasing every anidb entry it puts in there. Odd thing is it keeps the episode data from the correct show, but not the show data. I've had to lock the metadata to keep it from changing, but it keeps assigning those wrong codes while keeping the right ones. Any ideas, I mostly just want to stop it from fetching from the wrong sources.
VTMarik 0 Posted August 21, 2018 Author Posted August 21, 2018 (edited) Yes i do, but the diificulty is in emby grabbing info for the anime from 1979 (which has a different tvdb code and imdb code) instead of the live action original from 1966 UPDATE: Ok,i did not know that i could disable auto fetch. Problem Solved Edited August 21, 2018 by VTMarik
Luke 42212 Posted August 22, 2018 Posted August 22, 2018 You can also just try removing the anime plugin. That is a community contributed plugin and I'm not familiar enough with it to help troubleshoot it. Thanks.
