DSinapellido 7 Posted August 19, 2018 Posted August 19, 2018 I want to throw a 401 error whenever a user is not authenticated. For this, I included IHasResultFactory on my ServerEndpoint class class ServerEndpoint : IService, IHasResultFactory { public IHttpResultFactory ResultFactory { get; set; } public IRequest Request { get; set; } private readonly SimklApi _api; private readonly ILogger _logger; private readonly IJsonSerializer _json; public ServerEndpoint(SimklApi api, ILogger logger, IJsonSerializer json) { _api = api; _logger = logger; _json = json; } The thing is, I can't find the ThrowError function mentioned on https://github.com/MediaBrowser/Emby/wiki/Creating-Api-Endpoints I can't even find it on Github https://github.com/MediaBrowser/Emby.Common/blob/master/MediaBrowser.Controller/Net/IHttpResultFactory.cs How should, or how I can throw an http error if someone uses my Server Api Endpoint?
Luke 42238 Posted August 19, 2018 Posted August 19, 2018 You can instead just add the [Authenticated] attribute to your ServerEndpoint class.
DSinapellido 7 Posted August 20, 2018 Author Posted August 20, 2018 You can instead just add the [Authenticated] attribute to your ServerEndpoint class. But, Is there any way to use the ThrowError function or to return another HTTP Status code besides 200/500?
Luke 42238 Posted August 20, 2018 Posted August 20, 2018 No, you don't get to pick your response code.
