Headegg 0 Posted August 17, 2018 Posted August 17, 2018 Hi! I set up my server in a docker container running on an Asus tinker board. The server is underpowered for transcoding, I know, but there should be no need to, because the h.265 files can be hardware encoded by my mi box. Weirdly though, I have no sound when watching my videos. Only when I enable downsampling to 2.1 sound do I get sound. That makes the playback choppy or delayed by a few seconds, since the server can't keep up. Playing the files locally on another player it works flawlessly. Which settings should I look into to fix this?
Luke 42245 Posted August 17, 2018 Posted August 17, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
mastrmind11 722 Posted August 18, 2018 Posted August 18, 2018 Hi! I set up my server in a docker container running on an Asus tinker board. The server is underpowered for transcoding, I know, but there should be no need to, because the h.265 files can be hardware encoded by my mi box. Weirdly though, I have no sound when watching my videos. Only when I enable downsampling to 2.1 sound do I get sound. That makes the playback choppy or delayed by a few seconds, since the server can't keep up. Playing the files locally on another player it works flawlessly. Which settings should I look into to fix this? Is it possible that it's DTS audio and you haven't updated Android on the box?
ebr 16337 Posted August 18, 2018 Posted August 18, 2018 Is it possible that it's DTS audio and you haven't updated Android on the box? Also possible that their reported fix for DTS doesn't work. Did anyone ever confirm DTS working properly on Mi with the update?
mastrmind11 722 Posted August 18, 2018 Posted August 18, 2018 Also possible that their reported fix for DTS doesn't work. Did anyone ever confirm DTS working properly on Mi with the update?Yep. Works great. Sent from my SM-G965U using Tapatalk
ebr 16337 Posted August 18, 2018 Posted August 18, 2018 Yep. Works great. Sent from my SM-G965U using Tapatalk Great - I couldn't remember if we ever confirmed once Oreo was released. Thanks.
