rafailsar 0 Posted August 17, 2018 Posted August 17, 2018 Hello Emby Team, i want to use the build in live tv / tv tuner /m3u to play the live channels of this list: https://raw.githubusercontent.com/free-greek-iptv/greek-iptv/master/android.m3u i use the url method, i tried the m3u file method too but it didn't work either. execute read and write access was given. Basicaly for the test emby-server had root access. I works just fine with the iptv plug-in :S any idea ? Best Regards Rafael
Luke 42246 Posted August 17, 2018 Posted August 17, 2018 Hi there, what do you mean by "didn't work"? Can you please explain that? Thanks.
rafailsar 0 Posted August 17, 2018 Author Posted August 17, 2018 Hi, first of all thanks for the quick response If i add the m3u link i get that there are no compatible streams available. The think is that the streams are working and i can get them working on the iptv plug-in but not on the live tv. Could there be any association with transcoding ? Thank you for your time. Best Regards Rafael
Luke 42246 Posted August 17, 2018 Posted August 17, 2018 Thanks for the info. Can you attach the emby server log from the playback attempt? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks ! 1
rafailsar 0 Posted August 22, 2018 Author Posted August 22, 2018 Hi, sorry for the long waiting time. It works perfect now. All i needed to do was was activate intel quick sync and and use HEVC and MPEG2. Best Regards
