george.smathers 1 Posted August 16, 2018 Posted August 16, 2018 I am unable to get subtitles stored in external .srt files to display on my Roku streaming stick, I'm using Emby Beta Channel because the Beta version corrected the onerous screen flicker issue. I've tried all the user options for subtitles on the server: - Default - smart - Only forced subtitles - always play subtitles - no subtitles. None of these work. Subtitles embedded using ffmpeg display ok. Am I missing some setting or is this a beta problem? Any suggestion is appreciated.
Luke 42243 Posted August 16, 2018 Posted August 16, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
ebr 16335 Posted August 16, 2018 Posted August 16, 2018 Hi. FYI the beta and release versions are the same right now so you can go back to release if you wish. Can you please reproduce this problem and provide the information requested in How to Report a Problem? Thanks.
george.smathers 1 Posted August 16, 2018 Author Posted August 16, 2018 Problem disappeared!! Everything now works.Sorry for the trouble and many thanks for the quick response. PLEX RIP.
Luke 42243 Posted August 17, 2018 Posted August 17, 2018 Thanks for the feedback. Do you know what the solution was?
