Perun 1 Posted August 16, 2018 Posted August 16, 2018 Hi, I've a really ugly bug. On a complete clean install of stable (3.5.2.0 or beta 3.6.0.2 both as rpm for centos 7) I get ever a segfault if I want to use a picture library on the web ui. There no more infos only this if I start it on console: sudo -u kodi /opt/emby-server/bin/emby-server shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory Info Main: Application path: /opt/emby-server/system/EmbyServer.dll Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 4.17.13.1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system Info App: Application version: 3.6.0.2 Info App: Loading assemblies Info App: File /var/lib/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 Info App: File /var/lib/emby/plugins/IMVDb.dll has version 1.0.1.0 Info App: File /opt/emby-server/system/plugins/IMVDb.dll has version 1.0.1.0 Info App: File /var/lib/emby/plugins/OpenSubtitles.dll has version 1.0.2.0 Info App: File /opt/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.2.0 Info App: Loading Emby.Server.CinemaMode, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll Info App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll Info App: Loading MediaBrowser.Api, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.WebDashboard, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Model, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Common, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Controller, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Providers, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Photos, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Implementations, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.MediaEncoding, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Dlna, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.LocalMetadata, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Notifications, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.XbmcMetadata, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Connect, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Sync, Version=3.6.0.2, Culture=neutral, PublicKeyToken=null Info SqliteUserRepository: Sqlite version: 3.24.0 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal Info SqliteUserRepository: PRAGMA synchronous=1 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal Info AuthenticationRepository: PRAGMA synchronous=1 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal Info ActivityRepository: PRAGMA synchronous=1 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal Info SqliteItemRepository: PRAGMA synchronous=1 Info HttpServer: Calling ServiceStack AppHost.Init Info HttpServer: Adding HttpListener prefix http://+:8096/ Info HttpServer: Adding HttpListener prefix https://+:8920/ Info Skia: SkiaSharp version: 1.60.0.0 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 08/17/2018 02:00:00, which is 287.709494975 minutes from now. Info TaskManager: Daily trigger for Rotate log file set to fire at 08/17/2018 00:00:00, which is 167.709184321667 minutes from now. Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders ffmpeg version 4.0.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --arch=x86_64 --prefix=/home/embybuilder/Buildbot-master/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Info MediaEncoder: Decoder available: mpeg2video Info MediaEncoder: Decoder available: h264_cuvid Info MediaEncoder: Decoder available: hevc_cuvid Info MediaEncoder: Decoder available: mpeg2_cuvid Info MediaEncoder: Decoder available: mpeg4_cuvid Info MediaEncoder: Decoder available: vc1_cuvid Info MediaEncoder: Decoder available: vp8_cuvid Info MediaEncoder: Decoder available: vp9_cuvid Info MediaEncoder: Decoder available: ac3 Info MediaEncoder: Decoder available: aac Info MediaEncoder: Decoder available: mp3 Info MediaEncoder: Decoder available: h264 Info MediaEncoder: Decoder available: hevc Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders ffmpeg version 4.0.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --arch=x86_64 --prefix=/home/embybuilder/Buildbot-master/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Info MediaEncoder: Encoder available: libx264 Info MediaEncoder: Encoder available: mpeg4 Info MediaEncoder: Encoder available: msmpeg4 Info MediaEncoder: Encoder available: aac Info MediaEncoder: Encoder available: libmp3lame Info MediaEncoder: Encoder available: libopus Info MediaEncoder: Encoder available: libvorbis Info MediaEncoder: Encoder available: srt Info MediaEncoder: Encoder available: h264_nvenc Info MediaEncoder: Encoder available: hevc_nvenc Info MediaEncoder: Encoder available: h264_vaapi Info MediaEncoder: Encoder available: hevc_vaapi Info MediaEncoder: Encoder available: h264_v4l2m2m Info MediaEncoder: Encoder available: libwebp Info MediaEncoder: Encoder available: ac3 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -protocols ffmpeg version 4.0.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --arch=x86_64 --prefix=/home/embybuilder/Buildbot-master/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Info MediaEncoder: Encoder validation complete Info MediaEncoder: ffmpeg supported protocols: async,cache,concat,crypto,data,ffrtmphttp,file,ftp,gopher,hls,http,httpproxy,https,mmsh,mmst,pipe,rtmp,rtmps,rtmpt,rtmpts,rtp,srtp,subfile,tcp,tls,udp,udplite,unix,smb Info App: ServerId: f322dba9168944328d1601c52ffd7086 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0013596 seconds Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.2483849 seconds Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint Info App: Loading data from /var/lib/emby/data/connect.txt Info App: Loading data from /var/lib/emby/data/wan.dat Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.036262 seconds Info App: Core startup complete Info App: Post-init migrations complete Info App: Starting entry point Emby.Security.PluginSecurityManager Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.0001573 seconds Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0006095 seconds Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0.0001463 seconds Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0007338 seconds Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint Info App: Loading live tv data from /var/lib/emby/data/livetv/timers Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.50.90 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::4139:7050:698f:c01d%2 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.238862 seconds Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0004217 seconds Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0216898 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0005659 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.0005815 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001338 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0012154 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.000748 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0016707 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0011919 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0002104 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0018445 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0025376 seconds Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0010223 seconds Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0012556 seconds Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0013797 seconds Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0036671 seconds Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0015319 seconds Info App: Starting entry point Emby.Notifications.Notifications Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0005262 seconds Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.000186 seconds Info App: Starting entry point Emby.Security.PluginSecurityManager Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.000223 seconds Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint Info App: Sqlite version: 3.24.0 Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Info App: Default journal_mode for /var/lib/emby/data/sync14.db is wal Info App: PRAGMA synchronous=1 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0153854 seconds Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0015039 seconds Info App: All entry points have started Segmentation fault in log I see this: ... 2018-08-16 21:18:17.089 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 1ms. http://emby.chao5.int:8096/web/strings/de.json?v=1534447032432 2018-08-16 21:18:17.089 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 1ms. http://emby.chao5.int:8096/web/bower_components/emby-webcomponents/strings/de.json?v=1534447032432 2018-08-16 21:18:17.377 Info HttpServer: HTTP GET http://emby.chao5.int:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.384 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 7ms. http://emby.chao5.int:8096/emby/system/info/public 2018-08-16 21:18:17.388 Info HttpServer: HTTP GET http://emby.chao5.int:8096/emby/System/Info. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.502 Info App: App Activity: app: Emby Mobile, version: 3.6.0.2, deviceId: TW96aWxsYS81LjAgKFgxMTsgRmVkb3JhOyBMaW51eCB4ODZfNjQ7IHJ2OjYxLjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvNjEuMHwxNTM0NDQ1MTY4Mzg0, deviceName: Firefox 2018-08-16 21:18:17.576 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 188ms. http://emby.chao5.int:8096/emby/System/Info 2018-08-16 21:18:17.581 Info HttpServer: HTTP POST http://emby.chao5.int:8096/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.583 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.584 Info HttpServer: HTTP GET http://emby.chao5.int:8096/socket?deviceId=TW96aWxsYS81LjAgKFgxMTsgRmVkb3JhOyBMaW51eCB4ODZfNjQ7IHJ2OjYxLjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvNjEuMHwxNTM0NDQ1MTY4Mzg0. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.584 Error HttpServer: Could not find handler for /socket 2018-08-16 21:18:17.584 Info HttpServer: HTTP Response 404 to 192.168.50.100. Time: 0ms. http://emby.chao5.int:8096/socket?deviceId=TW96aWxsYS81LjAgKFgxMTsgRmVkb3JhOyBMaW51eCB4ODZfNjQ7IHJ2OjYxLjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvNjEuMHwxNTM0NDQ1MTY4Mzg0 2018-08-16 21:18:17.584 Info HttpServer: HTTP GET http://emby.chao5.int:8096/DisplayPreferences/usersettings?userId=3898dbf8fb684003af09d891795a0263&client=emby. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.640 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 56ms. http://emby.chao5.int:8096/DisplayPreferences/usersettings?userId=3898dbf8fb684003af09d891795a0263&client=emby 2018-08-16 21:18:17.653 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.679 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 96ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263 2018-08-16 21:18:17.679 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 26ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263 2018-08-16 21:18:17.701 Info HttpServer: HTTP Response 204 to 192.168.50.100. Time: 120ms. http://emby.chao5.int:8096/Sessions/Capabilities/Full 2018-08-16 21:18:17.727 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Views. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.743 Info HttpServer: HTTP GET http://emby.chao5.int:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.743 Info HttpServer: HTTP Response 304 to 192.168.50.100. Time: 0ms. http://emby.chao5.int:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2018-08-16 21:18:17.790 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Views. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.905 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 115ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Views 2018-08-16 21:18:17.905 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 178ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Views 2018-08-16 21:18:17.917 Info HttpServer: HTTP GET http://emby.chao5.int:8096/LiveTv/Programs/Recommended?userId=3898dbf8fb684003af09d891795a0263&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.967 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 50ms. http://emby.chao5.int:8096/LiveTv/Programs/Recommended?userId=3898dbf8fb684003af09d891795a0263&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio 2018-08-16 21:18:17.971 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.972 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.973 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=3898dbf8fb684003af09d891795a0263&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:17.974 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=e0f6d1369d7777621e65528a899b5ab4. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 2018-08-16 21:18:18.005 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 34ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2018-08-16 21:18:18.006 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 33ms. http://emby.chao5.int:8096/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=3898dbf8fb684003af09d891795a0263&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2018-08-16 21:18:18.042 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 70ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2018-08-16 21:18:18.059 Info HttpServer: HTTP Response 200 to 192.168.50.100. Time: 86ms. http://emby.chao5.int:8096/Users/3898dbf8fb684003af09d891795a0263/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=e0f6d1369d7777621e65528a899b5ab4 2018-08-16 21:18:18.094 Info HttpServer: HTTP GET http://emby.chao5.int:8096/Items/62372f4d957a4b7807318401986c3da9/Images/Primary?maxHeight=266&maxWidth=355&tag=af3107fd2c1e6774cc47683886dc2e86&quality=90. UserAgent: Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0 no more info etc... Does someone know this problem? On other art of lib (movie, tv shows etc) I dont have this problem... Greetz
Perun 1 Posted August 17, 2018 Author Posted August 17, 2018 this I can see in messages log: [704820.599106] EmbyServer[24473]: segfault at 0 ip 00007fd7169faf00 sp 00007fd699860bb8 error 4 in libc-2.17.so[7fd716984000+1c3000]
Perun 1 Posted August 18, 2018 Author Posted August 18, 2018 No one a hint? With this bug it is unusable for me...
Luke 42246 Posted August 18, 2018 Posted August 18, 2018 Hi, you will get a response. Thank you for your patience.
Luke 42246 Posted August 28, 2018 Posted August 28, 2018 There's nothing obvious here, but I did reproduce an image related crash and was able to resolve that. We should have that on the beta channel within the next couple days. Thanks.
Perun 1 Posted August 31, 2018 Author Posted August 31, 2018 Would be there a new beta version (for example 3.6.0.3) or should I download 3.6.0.2 again, is the fix already integrated?
Perun 1 Posted September 3, 2018 Author Posted September 3, 2018 updated and all works till now! thx a lot!
