BrendenCA 0 Posted August 16, 2018 Posted August 16, 2018 Hi, I just noticed today while browsing emby (the webapp), The aspect ratios aren't maintained for some cast images. For example, In the movie American Made, there is a member of the cast Jesse Plemons, his pic seems to be squeezed horizontally, making it look a bit weird. The exact pic in question can be found here for your testing, https://image.tmdb.org/t/p/original/4fdE4D8e2DEtFL4QgdorQOAI9RT.jpg I have narrowed down the issue to, https://github.com/MediaBrowser/emby-webcomponents/blob/master/cardbuilder/card.css#L277 Changing background-size to 'cover' seems to have solved the problem, and from my testing there doesn't seem to be any negative effect to the other images. I hope that helps you figure it out. Thanks,
Happy2Play 9811 Posted August 16, 2018 Posted August 16, 2018 (edited) @@LukeSome will not like the odd AR but why can't images be displayed like here? Instead of stretch to fit. Edited August 16, 2018 by Happy2Play
Luke 42242 Posted August 16, 2018 Posted August 16, 2018 I guess but the bordering at the top is kind of an eyesore.
Happy2Play 9811 Posted August 16, 2018 Posted August 16, 2018 I guess but the bordering at the top is kind of an eyesore. At the same time it lets the user know to look for better quality images.
BrendenCA 0 Posted August 17, 2018 Author Posted August 17, 2018 @@Luke Does the modification look good? Can, I make a PR? It would really help me build up my GH profile. Thanks,
Luke 42242 Posted August 17, 2018 Posted August 17, 2018 To be honest I lean towards keeping it the way it currently is.
BrendenCA 0 Posted August 17, 2018 Author Posted August 17, 2018 @@Luke, That's what the situation currently is, Surely, you want the aspect ratio to be maintained, poor chap above looks thin Plus, this image isn't that bad, it has a AR of 1.38. However, the more closer the image AR is to 1 the more badly skewed it will be.
