AxelAxel3 23 Posted August 16, 2018 Posted August 16, 2018 When using the Android App (Android 7.0), sometimes the volume controls does nothing. I can clearly see the volume bar on the Remote Control portion of the app, but the volume does not change. I know for sure I seen it with Trailers, but I believe I seen it in the movie library as well. I am also having this issue with the volume.. If my wife casts something say from Netflix and turns the Chromecast volume down, then I cast something via Emby, I can turn the Emby volume all the way up, but the Chromecast volume never gets adjusted, so I have to go into the Google Home app and turn the volume all the way up there, then I can adjust the volume accordingly in the Emby app.
Luke 42244 Posted August 16, 2018 Posted August 16, 2018 It will vary depending on the audio format being used for playback. If ac3 is being passed through to your tv or audio receiver, then you will need to change volume with that.
