tp546 41 Posted April 5, 2014 Posted April 5, 2014 I'm using the ROC theme and when I look at a TV series and go to the season level and hit the right arrow to go to season 2, it instead navigates me up to the top to the view and config menu. This is kind of driving me nuts because I have to dig out my mouse every time I run into this problem. 1
mboehler 94 Posted April 5, 2014 Posted April 5, 2014 I'm using the ROC theme and when I look at a TV series and go to the season level and hit the right arrow to go to season 2, it instead navigates me up to the top to the view and config menu. This is kind of driving me nuts because I have to dig out my mouse every time I run into this problem. I have the same issue.
leedavies 301 Posted April 5, 2014 Posted April 5, 2014 I'm using the ROC theme and when I look at a TV series and go to the season level and hit the right arrow to go to season 2, it instead navigates me up to the top to the view and config menu. This is kind of driving me nuts because I have to dig out my mouse every time I run into this problem. What view are you using? Thumb, coverflow, poster...?
tp546 41 Posted April 5, 2014 Author Posted April 5, 2014 What view are you using? Thumb, coverflow, poster...? Coverflow. I just noticed it only happens with shows that don't have enough seasons to create the wraparound effect, hopefully that helps.
amadeo36 6 Posted April 5, 2014 Posted April 5, 2014 Coverflow. I just noticed it only happens with shows that don't have enough seasons to create the wraparound effect, hopefully that helps. +1 Same problem
mariors44 18 Posted April 12, 2014 Posted April 12, 2014 Hi, Any updates coming soon? Cheers was wondering the same thing.
ABNParatrooper 6 Posted April 13, 2014 Posted April 13, 2014 Mine issue is sort of the same, but with all my movies. I can't jump to the right movie selection based on the letter pressed. For example if I press the letter A on my remote or keyboard, I expect to be take to movies that start with the corresponding letter. When I press a letter, I am taken to a totally different letter. In fact I press A I get Y or some random letter other than what I am supposed to get. I am on WIndows 8 running MBC.
SprBeast 6 Posted May 20, 2014 Posted May 20, 2014 So i'm not alone in this matter then I've just had to reinstall MB3 and the plugins after a Server HDD faliure and i am experiencing this issue too. Didn't happen on the previous version i was running and like the others it seems to effect Seasons that have no wrap around. If i change the view to a list style it works, but only until a restart. Is there any update from Lee regarding a fix? I love the 'ROC' theme and i would really hate to shift to another now that 'Neo' seems to have died.
Yogi 367 Posted May 20, 2014 Posted May 20, 2014 Is there any update from Lee regarding a fix? I love the 'ROC' theme and i would really hate to shift to another now that 'Neo' seems to have died. If you are looking for a Neo replacement try soultaker's new theme Square,it is similar to Neo in a lot of ways.
SprBeast 6 Posted May 20, 2014 Posted May 20, 2014 (edited) If you are looking for a Neo replacement try soultaker's new theme Square,it is similar to Neo in a lot of ways. Thanks for that Yogi, I've just installed that one now, on a side note i recovered an old Acronis image from my offsite NAS and I was able to "rollback" to a previous version of 'ROC' by copying the DLL, config and Roc folder out of Programdata and into the new install. What do you know, it works without a single hiccup. Hope this helps Lee and any other users. Edited May 20, 2014 by SprBeast 2
Dibbes 515 Posted May 20, 2014 Posted May 20, 2014 Thanks for that Yogi, I've just installed that one now, on a side note i recovered an old Acronis image from my offsite NAS and I was able to "rollback" to a previous version of 'ROC' by copying the DLL, config and Roc folder out of Programdata and into the new install. What do you know, it works without a single hiccup. Hope this helps Lee and any other users. A pity I don't have a copy of a previous DLL anymore... Care to share it?
ebr 16344 Posted May 20, 2014 Posted May 20, 2014 @@leedavies - how about you move the current release people are having problems with to "Beta" and then people who want to go back to the more stable version can just set their plug-in update level to Release and install that one.
leedavies 301 Posted May 26, 2014 Posted May 26, 2014 Thanks for that Yogi, I've just installed that one now, on a side note i recovered an old Acronis image from my offsite NAS and I was able to "rollback" to a previous version of 'ROC' by copying the DLL, config and Roc folder out of Programdata and into the new install. What do you know, it works without a single hiccup. Hope this helps Lee and any other users. Thanks - helpful. Looking into this issue now. ROC update on the way.
SprBeast 6 Posted May 28, 2014 Posted May 28, 2014 Sorry chaps, been away for a short break. Not sure on the ROC update timeline, but if Lee is happy for me to do so I can zip and share the "rolled back" version i am using if others require it.
amadeo36 6 Posted May 28, 2014 Posted May 28, 2014 Sorry chaps, been away for a short break. Not sure on the ROC update timeline, but if Lee is happy for me to do so I can zip and share the "rolled back" version i am using if others require it. Please, I'll be grateful if you share previous stable version
SprBeast 6 Posted May 29, 2014 Posted May 29, 2014 (edited) OK then, Here is a link to my dropbox. This is the version of ROC i am using, hope this helps. File is in standard ZIP format. edit: opps. I forgot to add. This is from my server location @ C:\ProgramData\MediaBrowser-Classic\Plugins It would be a good idea to backup your own files before overwriting, Also I shutdown Mediabrowser before I did the overwrite, then restarted the app. Edited May 29, 2014 by SprBeast
mariors44 18 Posted May 29, 2014 Posted May 29, 2014 OK then, Here is a link to my dropbox. This is the version of ROC i am using, hope this helps. File is in standard ZIP format. edit: opps. I forgot to add. This is from my server location @ C:\ProgramData\MediaBrowser-Classic\Plugins It would be a good idea to backup your own files before overwriting, Also I shutdown Mediabrowser before I did the overwrite, then restarted the app. thanks, but files seem to be corrupted.
SprBeast 6 Posted May 31, 2014 Posted May 31, 2014 Ah crap, sorry, entirly my fault. I had used a custom 7z compression by default. Here is a new link. I used Windows default compressed folders to create it so should be good. let me know, 4
mariors44 18 Posted May 31, 2014 Posted May 31, 2014 Ah crap, sorry, entirly my fault. I had used a custom 7z compression by default. Here is a new link. I used Windows default compressed folders to create it so should be good. let me know, thanks a lot Roc works much better for me. 1
