Morgan88500 0 Posted October 16, 2018 Author Posted October 16, 2018 (edited) Hi, the log in the attachement ! I can open the movie in my web brother (on my computer) but no in the application of BBOX .... Morgan log.zip Edited October 16, 2018 by Morgan88500
Luke 42239 Posted October 16, 2018 Posted October 16, 2018 Is the problem with the web app, or the android app?
Luke 42239 Posted October 17, 2018 Posted October 17, 2018 Can you provide a server log from playing in the android app? thanks.
Morgan88500 0 Posted October 29, 2018 Author Posted October 29, 2018 (edited) Can you provide a server log from playing in the android app? thanks. The log for the android player (the movie is "Braquage ...." Log.rtf Edited October 29, 2018 by Morgan88500
ebr 16333 Posted November 8, 2018 Posted November 8, 2018 @@ebr this is about android tv. thanks. I know. That's why I asked for this: If you can follow the instructions to send a log from the app after playing one of these items, I can see what information there is about what is happening. However, this is a custom implementation of Android for a particular provider in France. I have a feeling it just doesn't have everything needed for the app to work properly. I can see more if I can see a log though.
Morgan88500 0 Posted January 10, 2019 Author Posted January 10, 2019 Bonjour, regardez sur internet. C'est une box connecté à internet, qui permet d'avoir la télé via internet, d'installer des application, ...etc
Luke 42239 Posted January 10, 2019 Posted January 10, 2019 Bonjour, avez-vous suivi les instructions pour soumettre un journal in-app? Merci !
