ebr 16338 Posted August 19, 2018 Posted August 19, 2018 I have a guess at what may be going on here. For each of you with this problem, is your actual Fire TV device named something like "Bob's Fire TV"...? If so, can you try changing that name to something without that character and see if that makes a difference? Thanks. Edit: Sorry, it isn't the apostrophe - that should be fine. It is a character like ö 2
JerryPenguin 3 Posted August 19, 2018 Posted August 19, 2018 @Chief Bottle Washer thank you very much, that was the solution. The default name of Amazon: "[First Name]'s Fire TV" is the problem. I have renamed my Fire-TV on the Amazon web store to a simple name and now everything is going well again as usual. Thx for your efforts
ebr 16338 Posted August 19, 2018 Posted August 19, 2018 Okay, thanks for confirming. We will make the next release of the app work with those names but, for now, the solution will be to rename the device. Thanks. 1
maegibbons 1287 Posted August 19, 2018 Posted August 19, 2018 Well done @@ebr for some excellent detective work! Krs Mark
Newtonball76 0 Posted August 19, 2018 Author Posted August 19, 2018 Perfect, it worked! Thank you very much!
fracarvic 1 Posted August 20, 2018 Posted August 20, 2018 Removing the white space for default shield name "Android TV" and is working now. Thanks.
ebr 16338 Posted August 20, 2018 Posted August 20, 2018 Removing the white space for default shield name "Android TV" and is working now. Thanks. That name should not be a problem...
fracarvic 1 Posted August 20, 2018 Posted August 20, 2018 That name should not be a problem... It's strange, I renamed Android TV name and upgrade to 1.6.15 (playstore) from manually installed 1.6.0 and it's working now.
Frankel2012 0 Posted July 19, 2019 Posted July 19, 2019 For the record im getting these same errors on my Firestick 4k. I have just edited my fire tv name to one word and I will test it out over the coming days and report back. Im figuring if this does solve it the issue may have been the apostrophe in my name Barry's Fire TV.
Luke 42246 Posted July 19, 2019 Posted July 19, 2019 For the record im getting these same errors on my Firestick 4k. I have just edited my fire tv name to one word and I will test it out over the coming days and report back. Im figuring if this does solve it the issue may have been the apostrophe in my name Barry's Fire TV. Let us know how you get on. Thanks.
ebr 16338 Posted July 19, 2019 Posted July 19, 2019 Hi. This issue was fixed a long time ago so I imagine you are seeing something else. If the problem re-occurs, please create a new thread with details. Thanks. 1
hermanseverino 0 Posted October 10, 2019 Posted October 10, 2019 hola Adminitrador tengo un problema que me sale este mensaje cuando intentento conectar mi fire stick pongo mi cuenta Volley Error com.android.volleyError cual es la solucion a esto
Luke 42246 Posted October 10, 2019 Posted October 10, 2019 hola Adminitrador tengo un problema que me sale este mensaje cuando intentento conectar mi fire stick pongo mi cuenta Volley Error com.android.volleyError cual es la solucion a esto Hola, ¿en qué pantalla sucede esto exactamente?
ebr 16338 Posted October 10, 2019 Posted October 10, 2019 Hi. Make sure the actual device name of your Fire TV doesn't contain any accented characters.
Santobcn 0 Posted December 22, 2020 Posted December 22, 2020 hola me sale este mensaje al intentar iniciar " VolleyError com.android.volley.VolleyError:" te adjunto imagen. Me sale al iniciar la aplicacion. como puedo solucionarlo?
ebr 16338 Posted December 22, 2020 Posted December 22, 2020 Hi. Are you able to log in to your server after that?
vdatanet 1619 Posted December 22, 2020 Posted December 22, 2020 34 minutes ago, Santobcn said: hola me sale este mensaje al intentar iniciar " VolleyError com.android.volley.VolleyError:" te adjunto imagen. Me sale al iniciar la aplicacion. como puedo solucionarlo? Intenta esto, mira que el nombre del dispositivo no contenga caracteres especiales. On 10/10/2019 at 5:10 PM, ebr said: Hi. Make sure the actual device name of your Fire TV doesn't contain any accented characters.
ebr 16338 Posted December 22, 2020 Posted December 22, 2020 7 minutes ago, vdatanet said: Intenta esto, mira que el nombre del dispositivo no contenga caracteres especiales. This should not be necessary with the latest release of the app (.54) 1
Santobcn 0 Posted December 22, 2020 Posted December 22, 2020 Hola, si era eso. Amazon puso un caracter extraño en el nombre del aparato y al cambiarlo lo ha solucionado. Muchas gracias por todo. Y feliz navidad!!
vdatanet 1619 Posted December 22, 2020 Posted December 22, 2020 16 minutes ago, Santobcn said: Hola, si era eso. Amazon puso un caracter extraño en el nombre del aparato y al cambiarlo lo ha solucionado. Muchas gracias por todo. Y feliz navidad!! ¿Que versión de la aplicación utilizas?
vdatanet 1619 Posted December 22, 2020 Posted December 22, 2020 1 hour ago, ebr said: This should not be necessary with the latest release of the app (.54) I can confirm that this is not fixed. It is quite common to name the Firestick (by Amazon) in Spain in the following way: Firestick de John Doe 2º Firestick de John Doe (2º = 2nd) ... That º causes a volley error. I don't know if there are more chars causing this.
ebr 16338 Posted December 22, 2020 Posted December 22, 2020 18 minutes ago, vdatanet said: I can confirm that this is not fixed. It is quite common to name the Firestick (by Amazon) in Spain in the following way: John Doe Firestick 2º John Doe Firestick (2º = 2nd) ... That º causes a volley error. I don't know if there are more chars causing this. Can you please reproduce that and send me a log from the app? Thanks.
vdatanet 1619 Posted December 22, 2020 Posted December 22, 2020 7 minutes ago, ebr said: Can you please reproduce that and send me a log from the app? Thanks. I've send a log a couple of minutes ago. Server: embysrv Device Name: 2º Piso
ebr 16338 Posted December 22, 2020 Posted December 22, 2020 4 minutes ago, vdatanet said: I've send a log a couple of minutes ago. Server: embysrv Device Name: 2º Piso Thanks.
