lorac 119 Posted August 12, 2018 Posted August 12, 2018 I've noticed that DTS audio is not being converted in several emby applications including Roku (BN works though), LG & Android TV apps. So the media will play but there's no volume. Using server stable Version 3.5.2.0 Anyone else seen this / replicate it? 1
Luke 42212 Posted August 13, 2018 Posted August 13, 2018 HI there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
lorac 119 Posted August 13, 2018 Author Posted August 13, 2018 Here's your log file. Roku BN, ET, Emby for Android have sound. Roku, LG and Android TV do not. I've seen it with more than one media file. embyserver-63669706332.txt
lorac 119 Posted August 13, 2018 Author Posted August 13, 2018 The android for TV uses the TV speakers and the LG / roku are going through a Visio soundbar. Sent from my ONEPLUS A6003 using Tapatalk
lorac 119 Posted August 13, 2018 Author Posted August 13, 2018 I'm guessing not. The android app is running off of a STB connected to the TV. Most of the other media i played was AAC i believe. If i hookup my laptop to the TV and use ET i get sound with DTS. I just didn't see anything I could change to make it work with the other systems. It's inconvenient but I can work around it. As for the LG I didn't try it using the internal TV speakers but i can at some point. Sent from my ONEPLUS A6003 using Tapatalk
Luke 42212 Posted August 17, 2018 Posted August 17, 2018 Ok, we'll see what @@ebr thinks for Roku and Android TV. As far as LG goes, it is already planned for the future to create settings in the app to allow you to specify that it's not supported. There's no way as of now for us to detect this for LG. You can track this ticket here: https://github.com/MediaBrowser/Emby/issues/3388 Thanks.
lorac 119 Posted August 17, 2018 Author Posted August 17, 2018 Thanks Luke. Appreciated. Sent from my ONEPLUS A6003 using Tapatalk
ebr 16310 Posted August 17, 2018 Posted August 17, 2018 Hi. Can you please play one of these items that has no audio in the Android TV app and follow the instructions to send a log from the app? Thanks.
ebr 16310 Posted August 18, 2018 Posted August 18, 2018 If you are not hearing sound, there must be an issue with the outboard equipment involved. The system and the player report support for DTS: 08-17 16:33:44.136 3529 3529 I System.out: Reported device audio support is: ,ac3,eac3,dts,dca,dtshd ... 08-17 16:33:45.060 3529 3529 D EventLogger: Renderer:1 [ 08-17 16:33:45.060 3529 3529 D EventLogger: Group:0, adaptive_supported=N/A [ 08-17 16:33:45.060 3529 3529 D EventLogger: [X] Track:0, id=2, mimeType=audio/vnd.dts, channels=2, sample_rate=48000, language=eng, supported=YES 08-17 16:33:45.060 3529 3529 D EventLogger: ] 08-17 16:33:45.060 3529 3529 D EventLogger: ] 08-17 16:33:45.060 3529 3529 D Event The only odd thing is, I don't believe I've ever seen a 2 channel DTS track before. Perhaps the TV is not mixing it down properly due to that...
ebr 16310 Posted August 18, 2018 Posted August 18, 2018 Also, what is this Android TV device? I don't recognize it.
lorac 119 Posted August 18, 2018 Author Posted August 18, 2018 Telus TV Pik. I tried newer movies as well. Can't troubleshoot it any longer though as I was only with it for a week. Sent from my ONEPLUS A6003 using Tapatalk
ebr 16310 Posted August 18, 2018 Posted August 18, 2018 Okay, that's a specialized box for a streaming service that is only expecting Dolby audio so their DTS implementation may be incomplete.
lorac 119 Posted August 18, 2018 Author Posted August 18, 2018 Makes sense. Thanks for your help. Sent from my ONEPLUS A6003 using Tapatalk
Luke 42212 Posted August 19, 2018 Posted August 19, 2018 @@lorac, why you feel that it's not working in Roku? Can you please explain that? Thanks !
lorac 119 Posted August 19, 2018 Author Posted August 19, 2018 Because it wasn't At least on the LG TV w/ the Visio soundbar unless i play it in BN. I can test with a couple other Roku's tomorrow and see what happens. Sent from my ONEPLUS A6003 using Tapatalk
ebr 16310 Posted August 19, 2018 Posted August 19, 2018 Because it wasn't At least on the LG TV w/ the Visio soundbar unless i play it in BN. Was the soundbar hooked up via optical?
lorac 119 Posted August 19, 2018 Author Posted August 19, 2018 Yes. Sent from my ONEPLUS A6003 using Tapatalk
speechles 2062 Posted August 19, 2018 Posted August 19, 2018 In BN is the "Convert DTS to AC3" option set to yes?
Luke 42212 Posted August 19, 2018 Posted August 19, 2018 Is this one of those situations where the roku detects dts as being supported even though the audio equipment doesn't?
speechles 2062 Posted August 19, 2018 Posted August 19, 2018 (edited) Is this one of those situations where the roku detects dts as being supported even though the audio equipment doesn't? Yeah, it might be one of those where using "Auto detect" on the Roku in the section "Settings>Audio>HDMI and S/PDIF" might need to be set to "Dolby D" or "Dolby D+" instead. It can't really use optical to detect anything so just throws everything at the wall. So in effect "Auto detect" really is just another word for "allow everything" in that case. This should solve the problem without having to dig deeper, at least on the roku side of things. Edited August 19, 2018 by speechles
ebr 16310 Posted August 19, 2018 Posted August 19, 2018 I think it is a combination of outboard equipment. I think the TV does support DTS but, when sending it to a soundbar via optical cable, there isn't really a way to know if that soundbar supports DTS so the TV may just send it along untouched. There may be a setting in the TV itself to handle this situation.
lorac 119 Posted August 19, 2018 Author Posted August 19, 2018 It turns out that for my LG TV with Visio soundbar the issue is for media with FLAC 7.1 (5.1 works). I sent in a log about 15 minutes ago. The same movie does work with the same model roku with a different Visio soundbar (no sub though). It also works w/o any issue in BN. Sent from my ONEPLUS A6003 using Tapatalk
Luke 42212 Posted August 20, 2018 Posted August 20, 2018 Have you explored the audio settings in your TV?
