Hitec 1 Posted August 12, 2018 Posted August 12, 2018 New user here. I am having trouble streaming Opus audio to my Roku Ultra. The Roku gives a message of Playback Error - ignored. At first I thought Emby was trying to direct play the file in the opus format which is not supported by the Roku, but after looking at the logs, I do not believe that to be the case. The music file plays fine while streaming to my PC, phone, or Fire TV. I attached 2 log files. One while playing the Roku, and the other while playing on the Fire TV. Thank You Log Roku.txt Log Fire TV.txt
speechles 2062 Posted August 12, 2018 Posted August 12, 2018 (edited) The roku ultra can actually play back opus directly without transcoding. Why do you believe it isn't supported? It clearly shows in device.getAudioDecodeInfo() that roku ultra supports up to 5.1 (6 channel) in opus format. capabilities snipped. no give aways to p _ _ x playback snipped. no give aways to p _ _ x Edited September 23, 2018 by speechles
Hitec 1 Posted August 12, 2018 Author Posted August 12, 2018 (edited) Just going by this guide from roku. https://sdkdocs.roku.com/display/sdkdoc/Audio+and+Video+Support#AudioandVideoSupport-SupportedAudioFormats Supported Audio Formats Roku devices support the following audio file types: AAC: HE-AACv2, AAC-LC (CBR) MP3 WMA, WAV (PCM) AIFF FLAC ALAC Dolby Audio: Dolby Digital (AC3), Dolby Digital Plus (E-AC3) Passthrough: DTS Maybe this is old information? Edited August 12, 2018 by jbwindham
speechles 2062 Posted August 12, 2018 Posted August 12, 2018 Just going by this guide from roku. https://sdkdocs.roku.com/display/sdkdoc/Audio+and+Video+Support#AudioandVideoSupport-SupportedAudioFormats Supported Audio FormatsRoku devices support the following audio file types: AAC: HE-AACv2, AAC-LC (CBR) MP3 WMA, WAV (PCM) AIFF FLAC ALAC Dolby Audio: Dolby Digital (AC3), Dolby Digital Plus (E-AC3) Passthrough: DTS I dont think anybody developing for roku even looks at that anymore. It's not accurate. Yeah, the roku ultra supports opus. It clearly advertises this. Also has vorbis support which is also missing from that paste above. Roku expects developers to use this rather than some document humans must update. In this way the hardware is telling you what it supports. I just think ebr hasn't added the opus part. Easy enough, as the code to add support for it is quite simple. Now about why it didn't transcode and play for you anyways. It should do this its just a 2 channel opus stream. Weird... Other rokus that do not support OPUS playback directly will need transcoding to work.. So.. yeah.. just adding my 2cents here that it could be direct streamed just fine and didn't need transcoding...
Luke 42241 Posted August 13, 2018 Posted August 13, 2018 Well if it does support opus directly, then this will be an easy fix.
Hitec 1 Posted August 13, 2018 Author Posted August 13, 2018 Thanks for the replies. I can wait unitl a new release is out for this little bug. I have the Flac originals, and they play fine. Emby can be a little confusing if I have my regular "Albums" library and the "Flac Archive" library enabled. It shows multiple copies of the same album. Speechles, where did you get the "about your device" screen grab? I have looked all over for it.
Luke 42241 Posted August 13, 2018 Posted August 13, 2018 I've created a ticket for this on our internal tracker for us to look into. Thanks.
ebr 16334 Posted August 30, 2018 Posted August 30, 2018 Please test this with the beta version 3.0.102. Thanks.
Hitec 1 Posted August 31, 2018 Author Posted August 31, 2018 (edited) I just tried the beta version, and i have the same results, "Playback Error - ignored". Edited August 31, 2018 by jbwindham
Hitec 1 Posted August 31, 2018 Author Posted August 31, 2018 (edited) For giggles, I re-encoded trying different codecs. I don't know if this helps, but this is what worked and what didn't. Roku working MP3 - Lame 3.100 WMA - version 10 FLAC - 1.3.2 Roku not working Opus - 1.21 Ogg Vorbis - not sure which version AAC Fire TV Working MP3 AAC FLAC Ogg Vorbis Opus Fire TV Not Working WMA Edited August 31, 2018 by jbwindham
Luke 42241 Posted August 31, 2018 Posted August 31, 2018 Thanks for the testing feedback. We'll test those out.
ebr 16334 Posted August 31, 2018 Posted August 31, 2018 I just tried the beta version, and i have the same results, "Playback Error - ignored". You have transcoding enabled on your server, correct? Can you reproduce this and then follow the instructions to send a log from the app and also provide the server log and any ffmpeg logs that are generated at the same time? Thanks.
Hitec 1 Posted September 1, 2018 Author Posted September 1, 2018 Are there any other settings for transcoding that I might have missed other than the setting in the Users menu? Opus, WMA, MP3, & Flac do not produce transcoding logs. I assume it is trying direct playback so no transcoding is being done. OGG, and AAC produce the logs. AAC shows an error message of invalid data near the bottom of the log. Out of all the formats only WMA, MP3, and Flac work on my Roku. I also have a Speex file in my test directory, but it doesn't show up in Emby, so I assume that Speex is not supported. All recognized formats stream to my phone, browser, and the Emby windows app. I sent the log file from the Emby Beta app on the log file. AAC Transcode Log.txt OGG Transcode Log.txt Server.txt
ebr 16334 Posted September 4, 2018 Posted September 4, 2018 Can you please try this again with the latest app beta? Thanks.
Hitec 1 Posted September 4, 2018 Author Posted September 4, 2018 (edited) I just installed the new beta 3.0.103, and had some changes. AAC and Vorbis are now working, but Flac is broken and Opus is still not working. MP3 is working. Also it might be because it is a beta version, but I get a continuous "spinny thingy" on the screen while the music is playing. I included the log files. I sent the log from the Roku at 10:22pm Central time. Thanks AAC Log.txt Vorbis Log.txt Server Log.txt Edited September 4, 2018 by jbwindham
Hitec 1 Posted September 4, 2018 Author Posted September 4, 2018 One more thing I found, and I hope this helps. I can use the Roku media player app to connect to my NAS via a non Emby DLNA app running on the server. All files play correctly through Roku's built in media player.
Luke 42241 Posted September 4, 2018 Posted September 4, 2018 Thanks for the report. We'll take a look.
ebr 16334 Posted September 4, 2018 Posted September 4, 2018 I just installed the new beta 3.0.103, and had some changes. AAC and Vorbis are now working, but Flac is broken and Opus is still not working. MP3 is working. Also it might be because it is a beta version, but I get a continuous "spinny thingy" on the screen while the music is playing. I included the log files. I sent the log from the Roku at 10:22pm Central time. Thanks Hi. The log you sent from the app didn't contain any playback but it looks like only transcoded audio is working for you. I successfully played three different flac files with the beta yesterday. Do you have a sample of one that doesn't work for you (also opus)?
Hitec 1 Posted September 4, 2018 Author Posted September 4, 2018 I appreciate you helping me try to figure this out. Here are 4 samples I made with 2 different encoders, Freac, and T Audio Converter. In the filename of the samples you can see the version of the encoder used. None play through Emby beta 3.0.103, but all samples play through the Roku media player. The Flac samples play fine through the Emby 3.0.97 release. My Roku is on Software Version 8.1.0 (build 4145). The samples are zipped up because the website wouldn't permit me to upload audio files. Each file within the zip is a 29 second audio clip. Audio Samples.zip
Lane03 14 Posted September 17, 2018 Posted September 17, 2018 Also having an issue direct playing OPUS 5.1 audio. File plays fine using Roku Media Player. This is on a Roku 4K TV.
Happy2Play 9811 Posted September 17, 2018 Posted September 17, 2018 Also having an issue direct playing OPUS 5.1 audio. File plays fine using Roku Media Player. This is on a Roku 4K TV. Please list your Emby Roku app version number.
speechles 2062 Posted September 17, 2018 Posted September 17, 2018 Might also be related to opus not given direct stream ability. Aka a transcoding profile. See the other Roku threads I've posted in today. All are same scenario. Sent from my Nexus 7 using Tapatalk
Hitec 1 Posted September 26, 2018 Author Posted September 26, 2018 A big thank you to all the hard working developers. I just updated to the 3.0.108 beta release, and all audio formats are direct playing on the Roku now.
speechles 2062 Posted September 26, 2018 Posted September 26, 2018 (edited) A big thank you to all the hard working developers. I just updated to the 3.0.108 beta release, and all audio formats are direct playing on the Roku now. Actually, that is a misnomer. They should be, I wish they were. They work in the video player just fine. But it seems the RSGA apps and the SDKA apps are using a different audio player for some codecs. I've personally tested all my sample library, and believe me it is comprehensive. Ape and all those glorious extensions from the past. Any that could, are supported. So it is transcoding some, but reporting direct play. This is a known bug. I don't want to list the codecs supported (p _ _ x is way behind on the roku profile game), but rest assured I ran the gamut. When there comes a time that this changes I can give more information. But in all my tests with RSGA, you cannot play Flac, Opus, or Vorbis on firmware 8.1.0 build 4159-29. You can play this on this firmware with SDKA applications. So this tells me something is fishy at Roku Co. and this might be part of the OS9 rush. That bugs were left we just live with until then. They pulled all hands into rushing OS9 into the light. This might be part of it, or we might be at fault ourselves. It is too early to tell you but all the time spent checking for answers told me we arent doing anything wrong. So I must assume, the only thing it can be, is Roku. Edited September 26, 2018 by speechles
