ChrisKA 0 Posted August 11, 2018 Posted August 11, 2018 (edited) hi all, i just tried to install the emby server on my synology ds918+. The installation went through without problems. in package center the emby package is listed as running I just cannot reach the dashboard page any advice how to proceed would be highly appreciated thanks Chris Edited August 11, 2018 by ChrisKA
ChrisKA 0 Posted August 11, 2018 Author Posted August 11, 2018 OK I am able to answer my own question at least partially. When I deactivate the firewall I can access the dashboard. This is strange because with the firewall on. I only have default rules which should allow emby. Any thoughts?
Luke 42241 Posted August 11, 2018 Posted August 11, 2018 HI, do you mean the firewall in Synology? You must have had a conflicting rule that was causing it to get blocked. That's the only thing i can think of.
