sscheib 11 Posted August 10, 2018 Posted August 10, 2018 (edited) Hello, since some time (I cannot say since when exactly) the time shown in the Emby app on the FireTV shows the wrong time by exactly two hours. Currently it's 16:47 here and it shows 18:47 (well, 6:47). The time on the server itself is correct. Is there any setting within Emby to synchronize the time (I couldn't find one) or is it simply a bug or a setting on my FireTV I couldn't find? Oh BTW: It'd be great to have a 24H clock, instead of a 12H clock. Thanks! //EDIT:Using Sharp LC-40LE814E and FireTV 2 - if that matters. Edited August 10, 2018 by sscheib
Solution Luke 42245 Posted August 10, 2018 Solution Posted August 10, 2018 Hi there, have you checked your time zone settings on the client devices? 1
ebr 16337 Posted August 10, 2018 Posted August 10, 2018 Yeah this is coming from the system. I do believe you can set it to 24hrs too.
sscheib 11 Posted August 11, 2018 Author Posted August 11, 2018 Hello, I didn't know I could set it within the FireTV stick. It always showed up as correct, however I checked the timezone setting on the FireTV stick and it seemed to be wrong (although it was set to the correct timezone) - rebooting the stick fixed the issue for me. Thanks for your help!
