refrain 0 Posted August 10, 2018 Posted August 10, 2018 (edited) i was a XPEnology user and my server info at below DSM 6.2 with J3455 Motherboard with 4GB memory i can not playback when turn on the hardware transcode function by using (/dev/dri/renderD128) i only could play the movie with software transcode , but it cause the CPU usage very high. so what can i do? is there any incorrect setting that i set? in Attach. ffmpeg-transcode-8e7395ec-c4b3-40dc-8a82-5e3e45ada899.txt - VA API transcode ffmpeg-transcode-1f271c43-8ab2-4d06-97c2-678633022c97.txt - software transcode ffmpeg-transcode-1f271c43-8ab2-4d06-97c2-678633022c97.txt ffmpeg-transcode-8e7395ec-c4b3-40dc-8a82-5e3e45ada899.txt Edited August 10, 2018 by refrain
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 User [embysvr] was added to the group .
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 vainfo libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /var/packages/EmbyServer/target/ffmpeg/lib/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.1 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel® Broxton - 2.1.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD
Luke 42241 Posted August 10, 2018 Posted August 10, 2018 With software transcoding this is normal. Have you tried enabling vaapi hardware transcoding?
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 With software transcoding this is normal. Have you tried enabling vaapi hardware transcoding? OMG before i have getinfo use ./vainfo command that the process has never end and display nothing when vainfo run twice. so i have to restart the whole machine with DSM. after that, i could play the movie with using the hardware transcoding function. BUT, the whole machine with DSM has been reboot when the movie was playing 2 or 3 seconds. i have try twice, the reboot action always been there. so , i need to read the log now , and is there any problem cause that happen? i just use the Plex yesterday and it would be ok, so i guess when im installing EMBY process has some issue? should i need to reinstall EMBY?
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 i have reinstall the EMBY but the issue has not been solved that im playing the movie with hardware transcoding then the machine will been reboot. i think there would be some issue with the VAAPI or graphic drive?
Luke 42241 Posted August 10, 2018 Posted August 10, 2018 Can we see an ffmpeg log from when you enabled vaapi? thanks.
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 Can we see an ffmpeg log from when you enabled vaapi? thanks. i have uploaded two Attach files. i have reboot the whole machine with DSM. and first time i play the movie with hardware transcoding and played 1 mins . thats perfect. the log named "ffmpeg-transcode-d9cc37f8-d7bd-4314-bbf3-32e4e650d4e4.txt" then i close the web client window and i retry to play the same movie file, but the movie can not be play sucessful. so i found all the movie can not be play at this time. >_< the log named "ffmpeg-transcode-00ffd877-a762-498f-8390-38cf9139193f.txt" so strange. ffmpeg-transcode-d9cc37f8-d7bd-4314-bbf3-32e4e650d4e4.txt ffmpeg-transcode-00ffd877-a762-498f-8390-38cf9139193f.txt
refrain 0 Posted August 10, 2018 Author Posted August 10, 2018 (edited) server-log in Attach file server-201808102336.txt Edited August 10, 2018 by refrain
Luke 42241 Posted August 11, 2018 Posted August 11, 2018 Hi, can you try turning off the subtitles and see if that changes anything? thanks.
refrain 0 Posted August 11, 2018 Author Posted August 11, 2018 Hi, can you try turning off the subtitles and see if that changes anything? thanks. nothing gonna changes. so i have do downgrade my DSM from version 6.2 to 5.2. and retry to install EMBY again and wish it works successful. i open another forum thread to ask how to download the install file manually.
