Luke 42212 Posted August 10, 2018 Posted August 10, 2018 Can you explain your problem in more detail?
Guest asrequested Posted August 10, 2018 Posted August 10, 2018 Can you explain your problem in more detail?
Luke 42212 Posted August 10, 2018 Posted August 10, 2018 well i don't see the server's system folder either so perhaps they are just hidden.
Guest asrequested Posted August 10, 2018 Posted August 10, 2018 well i don't see the server's system folder either so perhaps they are just hidden. Exactly! But I've set it to not hide anything. Maybe I need to reboot it? I'll give that a try, later.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 I can't get it to show the system folder. So I can't put the dll in. Everything looks correct to show that folder, but it isn't showing. I'm stumped! Anyone got any suggestions?
Waldonnis 148 Posted August 11, 2018 Posted August 11, 2018 Easiest thing is just to search the filesystem for libSkiaSharp.dll, although it's probably faster to check what the executable path is for the server process via task manager (just find the process in the list, right-click it, and pick Properties). It's possible to do folder redirection for appdata via group policy, so maybe there's some local or group policy that redirected the install somewhere else. I have no idea what they changed in more recent Server versions in that regard or if they established some default other than what you'd see in the non-server OS variants.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 If I run dir from the command line, it tells me there are three directories. So they would seem to be present, I just can't get them to show in file explorer.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 The folder(s) are there, I just have no access to them. All the permissions are in place.
Luke 42212 Posted August 11, 2018 Posted August 11, 2018 @@CBers may have some tips about windows server.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 Ah jeez, I was looking under my user name. It's under administrator. So there are two directories?
Luke 42212 Posted August 11, 2018 Posted August 11, 2018 No, there's only one. Perhaps you ran the installer more than once under different credentials.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 No, there's only one. Perhaps you ran the installer more than once under different credentials. I didn't. Not sure what happened there, but I deleted the one under my user name. Replacing the dll, hasn't made any changes that I can see. Replacing all metadata and scanning etc, the images are still not appearing.
stony79 0 Posted August 11, 2018 Posted August 11, 2018 Ah jeez, I was looking under my user name. It's under administrator. So there are two directories? Do I understand that correctly, you installed emby with the administrator? and then you log in with your user and your user starts emby? At least it would explain why a part can be found under administrator and a part under your user. Then the images that are not displayed will probably be saved in your profile.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 Do I understand that correctly, you installed emby with the administrator? and then you log in with your user and your user starts emby? At least it would explain why a part can be found under administrator and a part under your user. Then the images that are not displayed will probably be saved in your profile. It's installed under administrator. I think the other folder may have came from the backup plugin, during restoration. As for logging in, as administrator. No matter what browser or machine I try this from, those images don't show. I have to use the process in the GIF.
stony79 0 Posted August 11, 2018 Posted August 11, 2018 Can you search in your user profile in the people folder for an actor whose picture is not displayed? maybe you can copy it into the administrator profile and see if it works. you can also try if you select a new image from an actor and download it to see if it is displayed correctly.
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 Can you search in your user profile in the people folder for an actor whose picture is not displayed? maybe you can copy it into the administrator profile and see if it works. you can also try if you select a new image from an actor and download it to see if it is displayed correctly. I've deleted that directory, and there are thousands of images, missing. This needs to be done on mass. I can't go one by one. And as I've mentioned, it isn't limited to prior added titles, it happens with newly added titles and trailer covers, too.
stony79 0 Posted August 11, 2018 Posted August 11, 2018 I'm aware of that. I just wanted to rule out what couldn't be causing it. When you select and download a new picture for an actor, is it displayed or not? If it is not displayed, is there the same people directory in your profile and is the image stored in it? Can you check in the task manager in the tab details which user is on embyserver.exe?
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 (edited) I'm aware of that. I just wanted to rule out what couldn't be causing it. When you select and download a new picture for an actor, is it displayed or not? If it is not displayed, is there the same people directory in your profile and is the image stored in it? Can you check in the task manager in the tab details which user is on embyserver.exe? Hey, you're right. When I download a new image, it's creating a directory in my user name. How do I correct that? And it's running under admin Edited August 11, 2018 by Doofus
stony79 0 Posted August 11, 2018 Posted August 11, 2018 Okay, we're getting close to it. can you check in task manager which user runs embyserver.exe? and in emby dashboard you can see the path for metadata, is the path to your user profile or to administrator?
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 and in emby dashboard you can see the path for metadata, is the path to your user profile or to administrator? admin
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 which user runs embyserver.exe? admin, everything is under admin
stony79 0 Posted August 11, 2018 Posted August 11, 2018 @ can you try to reboot your server and login with administrator and then change an image of an actor? @@Luke Do you have any idea why the images of actors are stored in another user's directory? do you ask the registered user instead of the user under which the server is running?
Guest asrequested Posted August 11, 2018 Posted August 11, 2018 @ can you try to reboot your server and login with administrator and then change an image of an actor? @@Luke Do you have any idea why the images of actors are stored in another user's directory? do you ask the registered user instead of the user under which the server is running? I've already tried that. No change. I'm going to try changing the path and then change it back. Maybe that'll correct it.
