bobaldis 24 Posted August 7, 2018 Posted August 7, 2018 Hi, Because of the issues using an MX Player as an External Player I'm trying to use the Internal Player, but the picture stutters and I find it unwatchable. I've tried playing the same media online, offline using built in speaker with no stutter, but soon as connected to Bluetooth Headset as I would on my daily commute the stutter appears. NB I've played the same media using a number of other installed Video Apps with the Bluetooth Headset with no issues, so don't believe it's the file or headset. Regards, Bob
bobaldis 24 Posted August 8, 2018 Author Posted August 8, 2018 Hi, Sony Z3 compact tablet running Sony's skinned Android 6.0.1. Thanks, Bob
Luke 42241 Posted August 8, 2018 Posted August 8, 2018 Can you try a low bitrate video and see if this happens? Thanks.
bobaldis 24 Posted August 8, 2018 Author Posted August 8, 2018 Hi, To avoid any confusion regarding definition of a low bitrate, perhaps you could share/link to a suitable media I could use? Just for my information, as I confirmed that I've played the same media in a number of other players via Bluetooth and your player through the speakers without issue, I'm unsure what this will prove/disprove? Bob
Luke 42241 Posted August 24, 2018 Posted August 24, 2018 Can you try the latest release of the app? thanks.
bobaldis 24 Posted August 24, 2018 Author Posted August 24, 2018 Hi, I'm running 3.0.10 and although not perfect it is a vast improvement, what was it and is there any further enhancements you can try? Bob
Luke 42241 Posted August 25, 2018 Posted August 25, 2018 We're continuing to try and improve the app with each new release. thanks !
Luke 42241 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
