Luke 42213 Posted September 21, 2018 Posted September 21, 2018 It's probably the video itself. Can you provide a copy of the media info from the web app? Thanks.
ctrlaltdefeat 8 Posted September 21, 2018 Author Posted September 21, 2018 You can find that here: https://i.imgur.com/ieNR6kz.png All of my movies are having this problem, but all are released by the same group and should be identical when it comes to codecs and such
Luke 42213 Posted September 22, 2018 Posted September 22, 2018 Thanks. @@softworkz will be taking a look at this.
ctrlaltdefeat 8 Posted September 28, 2018 Author Posted September 28, 2018 Another interesting thing(which I hadn't noticed sooner because I'm not really using Emby yet, because my movies aren't working) Other files(TV series) display subtitles when streaming, but when playing a synced file, the subtitle track is shown(see image), but aren't actually displayed when playing the video. https://i.imgur.com/NvLdgqs.png
Luke 42213 Posted September 28, 2018 Posted September 28, 2018 It's probably all related. Anyhow we know what the issue is and it will be resolved for the next release. Thanks.
ctrlaltdefeat 8 Posted October 27, 2018 Author Posted October 27, 2018 I just tested latest beta, and subtitles are now properly being displayed on media playback. However transcoding seems to fail for the movies earlier mentioned. Even though it still says 'Subtitle codec 94213 is not supported', the logs have changed. https://gist.github.com/CtrlAltDefeat94/1f5d6b2dceff1868b907775d23f16063
ctrlaltdefeat 8 Posted October 27, 2018 Author Posted October 27, 2018 Latest Android(phone and tablet) and Windows(laptop), both displayed the subtitles for all files I tried. Transcoding seems to work for my laptop, but not for my phone or tablet.
ctrlaltdefeat 8 Posted October 27, 2018 Author Posted October 27, 2018 (edited) Windows (from the Windows store): Emby 1.1.233.0 Android (from the playstore, both devices): Emby for Android 3.0.21 Edit, in the last message, I was referring to the version of the apps when i said "latest" Edited October 27, 2018 by ctrlaltdefeat
ctrlaltdefeat 8 Posted October 27, 2018 Author Posted October 27, 2018 Redmi Note 4 Android 7.0 NRD90M Samsung Galaxy Tab S3 (SM-T820) Android 8.0.0 My brother is unable to sync movies to his phone as well, he has a Huawei P8 Lite (Model ALE-L21). But the OS version I'm not sure, I'd have to ask.
ctrlaltdefeat 8 Posted October 28, 2018 Author Posted October 28, 2018 (edited) When I sync, I set the quality to 1.5mbps. This works on my laptop, but not on my Android devices. When I do playback(to both Android as Windows), it plays without transcoding, thus isn't crashing. Subtitles even work on all devices. If I were to sync at original quality, it won't transcode, and will play on all devices. Subtitles do work on my laptop<for some files>, but not on any of the Android devices. Edit, above mentioned appears to be universal, and not specific to earlier mentioned movies. Edited October 28, 2018 by ctrlaltdefeat
Luke 42213 Posted November 2, 2018 Posted November 2, 2018 Ok, the server should never try to mux mov_text into mkv because that is only supported within mp4. So that needs adjustment to handle the subtitles differently. Thanks.
