teddybear75 11 Posted January 23, 2019 Posted January 23, 2019 (edited) Can you try this version and see how it compares? https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks. Tried the 15.january update from play store, still a bit choppy on direct play, but seems somewhat better than before (my subjective opinion). The dropbox version you posted is still flawless, so im using that for now Edited January 23, 2019 by teddybear75
Luke 42245 Posted January 25, 2019 Posted January 25, 2019 The problem is if i disable hardware acceleration to possibly solve it for you, i'm just worried about potentially making it worse for others. That's even if i limit the change huawei.
teddybear75 11 Posted January 30, 2019 Posted January 30, 2019 (edited) That i can understand. Too bad though, as i would asume it affects quite a few Huawei users? Emby for android with external player could be an option if one wants to stay updated with the latest releases.... Edited January 30, 2019 by teddybear75
blinkiz 1 Posted February 12, 2019 Posted February 12, 2019 Two movies that have choppy playback with internal emby player is these two files. Big Buck Bunny, Sunflower version, bbb_sunflower_1080p_60fps_normal.mp4 Sintel, Sintel.2010.1080p.mkv Big Buck Bunny media info: VideoTitle 1080p H264Codec H264Codec tag avc1AVC YesProfile HighLevel 42Resolution 1920x1080Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 60Bitrate 4,001 kbpsBit depth 8 bitPixel format yuv420pRef frames 1NAL 4AudioTitle Und Dolby Digital 5.1 DefaultLanguage undCodec AC3Codec tag ac-3Layout 5.1Channels 6 chBitrate 320 kbpsSample rate 48,000 HzDefault YesContainer mp4Path /data/movies/Big Buck Bunny 2008/bbb_sunflower_1080p_60fps_normal.mp4Size 339 MB Sintel media info: Video Title 1080p H264 Codec H264 AVC Yes Profile High Level 41 Resolution 1920x818 Aspect ratio 2.35:1 Anamorphic No Interlaced No Framerate 24 Bitrate 10,562 kbps Colour space bt709 Bit depth 8 bit Pixel format yuv420p Ref frames 1 NAL 4 Audio Title Eng Dolby Digital 5.1 Language eng Codec AC3 Layout 5.1 Channels 6 ch Bitrate 640 kbps Sample rate 48,000 Hz Default No Container mkv Path /data/movies/Sintel 2010/Sintel.2010.1080p.mkv Size 1118 MB
Luke 42245 Posted February 17, 2019 Posted February 17, 2019 I guess for the next release we can try disabling h264 hardware acceleration for this manufacturer. Thanks.
teddybear75 11 Posted February 19, 2019 Posted February 19, 2019 I guess for the next release we can try disabling h264 hardware acceleration for this manufacturer. Thanks. Thats great news.
neik 874 Posted February 20, 2019 Author Posted February 20, 2019 I guess for the next release we can try disabling h264 hardware acceleration for this manufacturer. Thanks. Just wondering, doesn't deactivate hw acceleration cause higher power consumption as it is CPU decoded and thus lower battery time?
Luke 42245 Posted February 20, 2019 Posted February 20, 2019 That's the only answer i have right now as there's something going on specific to this manufacturer and we don't know exactly what it is yet. 1
Coxeroni 27 Posted February 26, 2019 Posted February 26, 2019 (edited) What is the status of this? Do we have to use this modified version posted on this thread somewhere? What about adding an optional switch for hardware acceleration, the "Huawei switch" Edited February 26, 2019 by Coxeroni
Luke 42245 Posted February 26, 2019 Posted February 26, 2019 Please try again with the next update to the app. Thanks.
ToyContinuum 0 Posted February 27, 2019 Posted February 27, 2019 I am having the same issue on my Huawei MediaPad M5 with same choppy issue. Can play the same file fine in Plex with Direct play but in Emby it stutters. Video Title1080p H264 CodecH264 AVCYes ProfileMain Level40 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate3,184 kbps Color primariesbt709 Color spacebt709 Color transferbt709 Bit depth8 bit Pixel formatyuv420Video Title1080p H264 CodecH264 AVCYes ProfileMain Level40 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate3,184 kbps Color primariesbt709 Color spacebt709 Color transferbt709 Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio TitleEng Dolby Digital 5.1 Default Languageeng CodecAC3 Layout5.1 Channels6 ch Bitrate640 kbps Sample rate48,000 Hz DefaultYes Audio TitleEng Dolby Digital stereo Languageeng CodecAC3 Layoutstereo Channels2 ch Bitrate640 kbps Sample rate48,000 Hz DefaultNo Containermk Ref frames1 NAL4 Audio TitleEng Dolby Digital 5.1 Default Languageeng CodecAC3 Layout5.1 Channels6 ch Bitrate640 kbps Sample rate48,000 Hz DefaultYes Audio TitleEng Dolby Digital stereo Languageeng CodecAC3 Layoutstereo Channels2 ch Bitrate640 kbps Sample rate48,000 Hz DefaultNo Containermk Not sure if this info helps. Thanks,
Luke 42245 Posted February 27, 2019 Posted February 27, 2019 Thanks for reporting. Please try again with the next update to the app. 1
Luke 42245 Posted March 7, 2019 Posted March 7, 2019 Can you please try this version and let me know how it compares: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks !
Coxeroni 27 Posted March 13, 2019 Posted March 13, 2019 Any news how this continues? I sense it is not top priority at the moment (which is ok). Will it make its way into the regular version or do I need to postpone play store updates for emby from now on?
neik 874 Posted March 14, 2019 Author Posted March 14, 2019 Yes it will. Hi Luke, just wondering, did you find a fix for the issue or did you implement the workaround (no hw accel.)?
Luke 42245 Posted March 22, 2019 Posted March 22, 2019 Please let me know if this version is still ok: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks.
teddybear75 11 Posted March 25, 2019 Posted March 25, 2019 Please let me know if this version is still ok: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks. Seemed to work fine on my Mediapad M5
