IceBoosteR 10 Posted August 4, 2018 Posted August 4, 2018 (edited) Hi there, I am using Emby on an Ubuntu VM and everything works fine. Due to nw hardware I want to make the switch and move to Docker. therefore I have installed ubuntu server 18.04 and docker of course, letting emby run with the following settings: docker run -d --restart unless-stopped --volume /docker/Emby:/config --volume /mnt/movies:/mnt/movies --device /dev/dri/renderD128 --publish 8096:8096 --publish 8920:8920 --env GIDLIST=44 emby/embyserver:latest But I do see problems with the docker configuration. Firsrt of all, I am using an Intel NUC (NUC7PJYH), which is able to handle 4K. Regardless of which video I start, 1 core is getting on 100% CPU utilisation, even if a movie has 360p, 480p I think this might be a bug. FFMPEG is using the horsepower only. On the other handside I have activated hardware acceleration (VAAPI) to use the power of the integrated Intel graphics. Therefore I have added the render node , and added the video group in the GID list.This should be all I thought. And finally, I do see errors in the logs. First, every movie I play is generation a "remux" file, which is not created when I run the same movie on the "old" system. I have not installed any additional graphics driver (like https://launchpad.net/~oibaf/+archive/ubuntu/graphics-drivers ), because I suggesated that the latest one will be installed by apt itself. root@athene:~# lspci -nnk | grep -iA2 vga 00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:3184] (rev 03) Subsystem: Intel Corporation Device [8086:2072] Kernel driver in use: i915 Or od I need something like: https://launchpad.net/ubuntu/+source/intel-vaapi-driver I have attached the logfile of the error messages. Maybe its my fault, maybe its not. I would be happy if you guys can help me here. Thanks! -Ice Edited August 4, 2018 by IceBoosteR
Luke 42213 Posted August 4, 2018 Posted August 4, 2018 Hi there, did you forget to attach the log file? Thanks.
IceBoosteR 10 Posted August 5, 2018 Author Posted August 5, 2018 (edited) Hi Luke, yes But this thime is is attached, I promise (I haven't seen the "attach this file" button need to be pressed aswell...) logfile emby.txt Edited August 5, 2018 by IceBoosteR
IceBoosteR 10 Posted August 5, 2018 Author Posted August 5, 2018 Hi, wasn't aware that you need those too. I have uploaded all logs created by one playback. Password in PM. logs.zip
Luke 42213 Posted August 6, 2018 Posted August 6, 2018 We pushed an update to our docker container earlier today to resolve an issue unrelated to this. Try updating and see if that helps here. Thanks.
IceBoosteR 10 Posted August 11, 2018 Author Posted August 11, 2018 Hi Luke, I have checked this today with the latest version. The problem still appears.
IceBoosteR 10 Posted August 15, 2018 Author Posted August 15, 2018 Could I please have an update? :/ On the other side, maybe a user can verify that my docker command is correct and I do not miss anything. That would be great. -Ice
IceBoosteR 10 Posted August 16, 2018 Author Posted August 16, 2018 We're looking into this, thanks. Thanks for the feedback Luke.
alucryd 318 Posted August 20, 2018 Posted August 20, 2018 What are the owner:group and permissions of the render node /dev/dri/renderD128 on your base system?
IceBoosteR 10 Posted August 20, 2018 Author Posted August 20, 2018 What are the owner:group and permissions of the render node /dev/dri/renderD128 on your base system? Hi @@alucryd, it is: root@athene:~# ls -lisa /dev/dri/renderD128 331 0 crw-rw---- 1 root video 226, 128 Aug 17 20:32 /dev/dri/renderD128 Where root has of course ID 0 and the video group is 44: video:x:44:
alucryd 318 Posted September 3, 2018 Posted September 3, 2018 Apologies for the delay. I don't have a vaapi capable cpu in my server anymore, but from what I can tell your docker run command is fine and permissions on the render node look fine as well. Could I get a glimpse of those ffmpeg logs as well? The intel driver is bundled in our docker image, this shouldn't be the issue. Still can you try: chmod 777 /dev/dri/renderD128 and restart docker to rule this out?
IceBoosteR 10 Posted September 3, 2018 Author Posted September 3, 2018 Apologies for the delay. I don't have a vaapi capable cpu in my server anymore, but from what I can tell your docker run command is fine and permissions on the render node look fine as well. Could I get a glimpse of those ffmpeg logs as well? The intel driver is bundled in our docker image, this shouldn't be the issue. Still can you try: chmod 777 /dev/dri/renderD128 and restart docker to rule this out? Hi, no problem. Thats good to hear. I will need some time to do it (not at home right now, but I will upload one as soon as I can. Normally I would not like to change anything to 777, else I would guess to see an "access denied" message if it is something with the permission. Cheers, Ice (I do apreciate the effort which has been done in the docker version and of course also in Emby itself!)
alucryd 318 Posted September 4, 2018 Posted September 4, 2018 I understand, 666 would be enough as well, that's what we went with on arch linux. That render node is not critical, it doesn't really need to be protected. FYI, I'm going on vacation with little to no internet access this evening for about a week. I'll get back to you when I come back home.
IceBoosteR 10 Posted October 3, 2018 Author Posted October 3, 2018 (edited) So I do see in the current version that now all 4 cores are used. Iam still investigating why the playback on my TV is stutters, because CPU is no more used as 30% over all. I am looking into this if this is maybe due to the render node. Disabled the render node and it was even worse. Edited October 3, 2018 by IceBoosteR
IceBoosteR 10 Posted October 6, 2018 Author Posted October 6, 2018 Hi Luke, as I said previously, when I change from VAAPI to no hardware encoding, the video playback stops every second and needs a second to load. With VAAPI it is only every third second. But this is only true when I chhose Dolby Atmos /True-HD as soundtrack. DTS and normal DD is fine.
Luke 42213 Posted October 6, 2018 Posted October 6, 2018 Can we look at the ffmpeg log from an example? thanks.
IceBoosteR 10 Posted October 7, 2018 Author Posted October 7, 2018 @@Luke of course. I will generate those when I am home!
IceBoosteR 10 Posted October 7, 2018 Author Posted October 7, 2018 (edited) @@Luke As requested the transcoding log. I have used VAAPI as mentioned, it is much smoother as without but still unwatchable. But this is "only" TRUE-HD not Atmos as far as I can see it. emby remux log.txt Edited October 7, 2018 by IceBoosteR
Luke 42213 Posted October 9, 2018 Posted October 9, 2018 This particular example wont' make any difference with vaapi on or off because no video transcoding is occurring.
IceBoosteR 10 Posted October 17, 2018 Author Posted October 17, 2018 Interesting. But there is a difference in playback... -Ice
Luke 42213 Posted October 18, 2018 Posted October 18, 2018 We'll have an updated ffmpeg with the next release. I would try again with that. Thanks.
