inforbaix 5 Posted April 3, 2014 Posted April 3, 2014 Hi, Now I actualized MBC to the version 3.0.148.0 (Beta), and I observed when navigating by my movies folder, what at certain movies (random) with videobackdrops included, the word "ENDS" that normally indicates the hour of movies end, indicates only 1 or 2 minutes avant of the actual hour. It's possible indicates the end of videobackdrop? Any with Videobackdrops enabled can check that? Thank's! N: Sorry for my english
ebr 16334 Posted April 4, 2014 Posted April 4, 2014 More likely those particular items don't have accurate length data. What do they show in the web client for running time?
inforbaix 5 Posted April 4, 2014 Author Posted April 4, 2014 You're right, in the web client either leaves the movie length. Sorry.
ebr 16334 Posted April 4, 2014 Posted April 4, 2014 Try refreshing them from the web client editor. If that doesn't fix it then we cannot read that file for some reason.
