otsuzi 0 Posted August 3, 2018 Posted August 3, 2018 (edited) Hi I don't know since when, but a specific set of videos are not playing sound on the LG app, but on the web is working just fine. I do remember to watch this videos with sound on previous versions the LG app (maybe a long time ago). I'm using LG app version 1.0.9 (I've tested with 1.0.8 also) and server version 3.5.1.0 Filename: Halt_and_Catch_Fire_S01E01_x265_1080p_BluRay_30nama_30NAMA.mkv The server log can be found attached to this post with the name: error_with_halt_and_catch_fire.txt The file "result_from_ffmpeg.txt" has the result from the command ffmpeg -i Halt_and_Catch_Fire_S01E01_x265_1080p_BluRay_30nama_30NAMA.mkv This information was available at the "stats for nerd" Playback Info Player: HTML Video Player Play method: Directy Play Protocol: HTTP Stream type: Video Video Info Video resolution: 1920x1080 Orginal Media Info Container: mkv Bitrate: 1.2Mbps Video Codec: HEVC Main 10 Video bitrate: 1.2Mbps Audio Codec: OPUS Audio Channels: 6 Audio Sample Rate: 48000Hz error_with_halt_and_catch_fire.txt result_from_ffmpeg.txt Edited August 3, 2018 by otsuzi
Luke 42234 Posted August 3, 2018 Posted August 3, 2018 Hi there, can you please attach the complete ffmpeg log? this appears to only be a portion of it. Thanks.
otsuzi 0 Posted August 3, 2018 Author Posted August 3, 2018 In order to do this report, I've cleaned the whole folder /var/lib/emby/logs. After that, I started the Emby server and played the video for 2 or 3 minutes. After this procedure, the folder "/var/lib/emby/logs" had just this file in attachment (was named emby_server.txt I think). Right now I'm not in front of my pc when I get back to it I will check if this ffmeg log was generated
