Mazter Jedi 3 Posted August 2, 2018 Posted August 2, 2018 (edited) I have recently found a couple of movies backed up from a Blu-ray that for whatever reason were only encoded in stereo. I would like to go get the disc and re-encode them properly in 5.1. Is there a way to sort the files in you library by audio type? Just want to check for any others. TIA. Edited August 2, 2018 by Mazter Jedi
Luke 42212 Posted August 2, 2018 Posted August 2, 2018 Hi, currently no, but it's a good idea for the future. In the meantime one of the reporting plugins might help you. Thanks.
Mazter Jedi 3 Posted August 2, 2018 Author Posted August 2, 2018 the Reports plugin or Emby data...which one you think? Never used either.
Luke 42212 Posted August 2, 2018 Posted August 2, 2018 I am only familiar with reports. It does have audio codec as a column although i don't recall if you can sort by that or not.
