enny.nz 0 Posted August 2, 2018 Posted August 2, 2018 Hi, Since last week my Emby started creating double thumbnails and metadata information for my movies. They are saved into folders and usually, it would only put the metadata into that folder. But now he creates metadata and images also outside the folders. Anyone has this problem and found a solution? I've tried to delete the images outside the folders and refresh the metadata, but it keeps recreating it. Any help is highly appreciated. Thank you!!
ebr 16310 Posted August 2, 2018 Posted August 2, 2018 Hi. Can you show us a screen shot of exactly what you are talking about? Thanks.
enny.nz 0 Posted August 11, 2018 Author Posted August 11, 2018 Hi, thank you for your reply. Here are some screenshots: As you can see several movies have a double thumb. One plays and the other one is just a thumb without media attached to it. If I go into Windows Explorer you can see that I have the movies saved into folders. Each folder contains the movie file, metadata, and images: What Emby does is now creating metadata also outside the folder: I'm not sure what changed here, as it didn't do it before. Cheers!
Luke 42212 Posted August 11, 2018 Posted August 11, 2018 if you use the metadata editor on both of the two abyss entries, what paths do they point to?
enny.nz 0 Posted August 12, 2018 Author Posted August 12, 2018 The first one points to: G:\Movies\The Abyss (1989).mp4 The second one point to: G:\Movies\._The Abyss (1989).mp4
