ebr 16337 Posted August 3, 2018 Posted August 3, 2018 We currently run all live TV through the server in some fashion so that it is possible to share streams. e.g. Three TVs all watching the same channel only use one tuner on your hardware. 1
Spaceboy 2573 Posted August 4, 2018 Posted August 4, 2018 We currently run all live TV through the server in some fashion so that it is possible to share streams. e.g. Three TVs all watching the same channel only use one tuner on your hardware.is that true even in the web client when using an iptv source? I’ve been recording my streams and watching the recording when at work because I assumed it would play the url directly and I don’t want that url to be logged
Carlo 4561 Posted August 4, 2018 Posted August 4, 2018 It's coming from your server. BTW, how would you watch a "recording" if it didn't come from your server? If you want to watch live streams at work without going through your server just use VLC with the M3U file.
ebr 16337 Posted August 4, 2018 Posted August 4, 2018 is that true even in the web client when using an iptv source? I’ve been recording my streams and watching the recording when at work because I assumed it would play the url directly and I don’t want that url to be logged Yes, that is especially true with IPTV sources. 1
Spaceboy 2573 Posted August 4, 2018 Posted August 4, 2018 Yes, that is especially true with IPTV sources.good to know
