annisman 13 Posted July 31, 2018 Posted July 31, 2018 (edited) Hi, I've tried naming the movies according to the wiki article but am not having any luck. I have a BD and 4K version of Saving Private Ryan, both files are inside of a file named "Saving Private Ryan", the BD video file is named "Saving Private Ryan [1080p]" and the 4K is "Saving Private Ryan [2160p]" which the wiki article states to do. However when scrolling through my movies in coverflow it is showing me two seperate videos, it also shows me two seperate videos on Emby server. Thoughts ? (I've attached two pictures as well) Edited July 31, 2018 by annisman
annisman 13 Posted July 31, 2018 Author Posted July 31, 2018 I dont understand the question... both my .mkv tips are under one folder "Saving Private Ryan" which is inside a "UHD" folder which is included in my emby library structure.
annisman 13 Posted July 31, 2018 Author Posted July 31, 2018 One of the pictures I provided should show you what my folder looks like, I have highlighted both the mkv files in there for you.
Luke 42212 Posted July 31, 2018 Posted July 31, 2018 So they're both video files? you said bluray so i wasn't sure if it was a folder bdmv structure. i really need to see the entire contents of the folder. thanks.
annisman 13 Posted July 31, 2018 Author Posted July 31, 2018 Here is everything in the folder (minus the backdrops, which I removed to make it easier to take a pic)
ebr 16310 Posted July 31, 2018 Posted July 31, 2018 You are using Emby for WMC? If so, you are going to want to keep those separate like that because that app won't understand the two different versions and give you individual access to them.
Luke 42212 Posted July 31, 2018 Posted July 31, 2018 Can I also see the folder path, can you include that as well? Thanks.
annisman 13 Posted July 31, 2018 Author Posted July 31, 2018 Can I also see the folder path, can you include that as well? Thanks. I am at work now so I can't take any more pictures, but the folder path is very simple. Hard-drive > "UHD" > "Saving Private Ryan" "UHD" folder is included in my Emby movie Library. What is in the "Saving Private Ryan" folder I have show in my last attachment above.
annisman 13 Posted July 31, 2018 Author Posted July 31, 2018 (edited) You are using Emby for WMC? If so, you are going to want to keep those separate like that because that app won't understand the two different versions and give you individual access to them. That's a little disappointing but certainly not a deal breaker, maybe that should be pointed out in your wiki article - because it gave me the assumption that it would work for me in WMC Emby. Edited July 31, 2018 by annisman
Luke 42212 Posted August 1, 2018 Posted August 1, 2018 Yes you're right, thanks for the feedback. Emby for WMC is based on our older Media Browser 2 app and it's just been a challenge adding new features to it without breaking other areas. I would suggest checking out our new app for windows, Emby Theater: https://emby.media/emby-theater.html This is designed to fully replace windows media center. Thanks !
annisman 13 Posted August 1, 2018 Author Posted August 1, 2018 (edited) Yes you're right, thanks for the feedback. Emby for WMC is based on our older Media Browser 2 app and it's just been a challenge adding new features to it without breaking other areas. I would suggest checking out our new app for windows, Emby Theater: https://emby.media/emby-theater.html This is designed to fully replace windows media center. Thanks ! I am using MPC-BE as an external player, does Emby Theatre support that ? How is Emby Theatre with HDR passthrough ? Do you think the internal player is comparable or better than MPC-BE with MadVR ? Edited August 1, 2018 by annisman
Guest asrequested Posted August 1, 2018 Posted August 1, 2018 I am using MPC-BE as an external player, does Emby Theatre support that ? How is Emby Theatre with HDR passthrough ? Do you think the internal player is comparable or better than MPC-BE with MadVR ? You can still use external players, but you may want to try the internal player, first. MPV is very good.
annisman 13 Posted August 1, 2018 Author Posted August 1, 2018 Should I download Theater real quick and give the player a whirl ? Will installing Theater mess with my current Emby for WMC setup if I don;'t like it and uninstall ?
Guest asrequested Posted August 1, 2018 Posted August 1, 2018 Should I download Theater real quick and give the player a whirl ? Will installing Theater mess with my current Emby for WMC setup if I don;'t like it and uninstall ? It won't affect anything else. You could use both.
