cbdudek 17 Posted July 31, 2018 Posted July 31, 2018 (edited) I have been trying to update Emby to the latest version to no avail. It says it is ready to install, and to restart the server. I restart the server though and it comes back to where it was. It updates 3.5.1.0 again and then asks to reboot. I restarted the server manually. I also restarted the Windows box that it is on. I am not seeing any issues in the event viewer. Anything else I can try? Edited July 31, 2018 by cbdudek
Solution Luke 42212 Posted July 31, 2018 Solution Posted July 31, 2018 Try rebooting the machine and then running the installer from the website. 2
cbdudek 17 Posted July 31, 2018 Author Posted July 31, 2018 I just finished and it appears to be running and fully updated. This is good to know for the future if I see this issue again. Thanks!
