mbu10 3 Posted July 30, 2018 Posted July 30, 2018 it been sat at this % for about a day have restarted a couple of times, and jumps to this number really quickly should i just leave it or how do i trouble shoot it i am a lifetime emby member now from plex and they had an issue so came over here as been playing with it for a while so far so good bar this scan thing stopping mbu
ebr 16310 Posted July 30, 2018 Posted July 30, 2018 Hi. Please see: How to Report a Problem To see how to post the log. Also, you can just watch the log file to see if it is growing. In which case, the scan is progressing.
mbu10 3 Posted July 31, 2018 Author Posted July 31, 2018 (edited) my scan is still at 87% after a day so have included the logs have restarted emby a couple of times have even put the .ignore file in 2 of the directorys as i do not need to scan 2 of them thanks EMBYLOGS.txt Edited July 31, 2018 by mbu10
Luke 42212 Posted July 31, 2018 Posted July 31, 2018 Hi, it looks like it is running just fine to me. I would just be patient and allow it to finish. If you'd like to improve the performance of your library scan, consider removing these plugins: 2018-07-31 02:05:44.747 Info App: Loading statistics, Version=2.0.5.1, Culture=neutral, PublicKeyToken=null from C:\Users\administrator.MAIN\AppData\Roaming\Emby-Server\plugins\Statistics.dll Please let us know if this helps. Thanks.
mbu10 3 Posted July 31, 2018 Author Posted July 31, 2018 well went through the logs and the last entry for debugging was a single photo, (there are 7 thousand in there) so removed the single photo and starting processing normally so all good now and done 100% in a couple of mins thanks for the pointers where you looked so i could find out what it was
