tdiguy 99 Posted July 30, 2018 Posted July 30, 2018 I am trying to figure out where this change came from, i have multiple shows i had set up for series recording. For example one of them was Bunk'd. This stopped recording and when i looked at the series recording nothing showed up under the schedual section which to me was odd normally something shows up there anyway even if its not going to be recorded. So i searched for bunk'd and set it up to record. It recorded an episode and now i see a new entry for it under series record setting and in the schedual part i see all the times its going to come on and if its going to record. Looking at the files i see my old directory Bunk'd and a new Bunk'd (2015). Is this because of an update to emby or because i switched from xmltv to schedules direct?
Luke 42246 Posted July 30, 2018 Posted July 30, 2018 or because i switched from xmltv to schedules direct? Yes this is why. Currently you need to setup recordings again in the event of changing guide providers.
tdiguy 99 Posted July 30, 2018 Author Posted July 30, 2018 Yes this is why. Currently you need to setup recordings again in the event of changing guide providers. Ok, thank you.
